Thread: Exterior Lighting Problems
Results 1 to 5 of 5
  1. #1 Exterior Lighting Problems
    Nov 2010
    Texas
    I have a 2000 Grand Prix that is have some lighting issues. The head lights (DLR) and tail lights will not come on at night. I have to twitch to high beams but even at this the tails lights will still not light up.The brake lights will work but everything else seems to just have stopped.
    I replaced the DLR 10 amp fuse and tested the 20amp headlamp circuit breaker fuse and that is ok.
    Any ideas on what this could be? Thanks for the help!!
  2. #2 Re: Exterior Lighting Problems
    Ocala, FL
    DLR = Daily lights that run?
    (DRL)
    Anyway, it's the automatic lights that would be the problem, not drl's. Drl's are just on when your headlights aren't.
  3. #3 Re: Exterior Lighting Problems
    Nov 2010
    Texas
    Does the automatic lights have a sensor or fuse that I can replace to see if that would correct the problem?
  4. #4 Re: Exterior Lighting Problems
    Ocala, FL
    Theres a sensor on the front of the dash near the windshield.
  5. #5 Re: Exterior Lighting Problems
    Nov 2010
    Texas
    Yea, I have seen it. Is that a DIY project or is it a complicated process that an electrician should do.
  1. Help with lighting please
    By sinceregtp in forum Visual/Body Modifications
    Last Post: 04-15-2010, 10:59 PM
  2. LIGHTING for an 04 GTP
    By ne04gtp in forum Shops and Community Heroes
    Last Post: 02-05-2010, 05:49 PM
  3. exterior
    By CHAMPS97 in forum Visual/Body Modifications
    Last Post: 06-16-2009, 11:18 PM
  4. exterior upgrades
    By superv6 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:26 PM
  5. Exterior Lighting Delay Question
    By brian0488 in forum General Tech Discussion
    Last Post: 02-13-2009, 09:01 PM
