Thread: abs/traction/stability service lights
Results 1 to 9 of 9
  1. #1 abs/traction/stability service lights
    langley, bc
    Ok i talked to gm about this problem that we all eventually get once or 10 times with our cars...
    with the shaking of the abs at low speed braking .. and or the abs, traction or stability needing serviced..
    well aparently the guy said they dont get enough feedback about this problem.. so please feel free to email to him/her
    saying you have this problem and scanned it as such ..
    the more emails the better chance of having this become a factory recall and we all get it fixed for free.
    socialmedia@gm.com
    re: grand prix wheel hub sensor
  2. #2 Re: abs/traction/stability service lights
    Charles City, IA
    wheel bearings good bad on all cars deal with it or dont drive.
    SMGPFC Two Nipple General
  3. #3 Re: abs/traction/stability service lights
    langley, bc
    sry i forgot to mention 04 or up owners and its not the bearings its the harness's have a defect where they fill with water, and for the comp g owners who have to replace it every 4 months, ..please do your research before you make your dumb-ass comments.
  4. #4 Re: abs/traction/stability service lights
    Charles City, IA
    Quote Originally Posted by jackster1234 View Post
    Yes my comments are all pointless and dumb, how about you do some research. Untill there is a death or risk of deaths from this it will not get recalled.
  5. #5 Re: abs/traction/stability service lights
    langley, bc
    not true ive seen recalls done on the grand prix b4 done with just emails.. and proof of the problem in a certain amount of cars..
    and it is a risk of death! the abs goes in and out causing the brakes to fail.
  6. #6 Re: abs/traction/stability service lights
    Charles City, IA
    The brakes dont fail, you just dont have abs, my abs has not work for years Im still alive. If you get the recall to go threw good for you, but I dont think it will happen.
  7. #7 Re: abs/traction/stability service lights
    langley, bc
    holy crap buddy i am speaking from experience on the 04 comp g's when the harness fills with water the brakes pulsate unsure whether to turn on of off not letting you brake your seriously being an idiot forget it i already go 240 gtp owners who know what im talking about to email them .. tired of wastin my time here where most owners are 99 gp
  8. #8 Re: abs/traction/stability service lights
    Charles City, IA
    Ok, I thought you were talking about a different problem, I would pull the abs fuse to prevent that from happening, where does the harness fill with water>?
  9. #9 Re: abs/traction/stability service lights
    langley, bc
    thats actually a good idea thanx, its right behind the wheel. some of the other guys said the water actually fried there wires further back under the rad area so i have yet to check that.
    at low speeds the sensor causes the brakes to seriously pulsate to the point where i cant stop (mostly when it has rained or after i wash the car) the scanner says its the wheel hub sensor itself but ive already changed it and it didnt fix it so i changed the harness at the beginning of summer and it fixed it till recently now i saw it just flooded the harness. gm knows its a problem and they up to this point were calling it just a fault of the 2004 plus gtp's
  1. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  2. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  3. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  4. 04 GTP Service ABS/ TRaction control
    By busagtp in forum General Tech Discussion
    Last Post: 09-07-2009, 12:03 PM
  5. reduce engine power / service traction system
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 06:56 PM
