Hi,
Daughter just bought her first car and we found that the driver's side window won't go down. So I pulled off the door panel and popped off the electrical connector to see if voltage was getting to the motor. I had +12v and -12v when I operated the switch both ways (and zero of course when the switch was in neutral). So I ordered a new window motor.
So today I removed the old motor and was ready to put the new motor in. I thought I'd give the new motor a quick check and plugged it in. When I hit raise, the motor operated one way. So I hit lower and got nothing. I traded motors (old for new) and got the same results. No motor operation when trying to lower the window. I removed the motor and rechecked that there was voltage going to the plug and there was for both raise and lower, just like before.
Now what?
Thanks
