Thread: UGH! Help with EGR valve...
Results 1 to 17 of 17
  1. #1 UGH! Help with EGR valve...
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    So on the 24th my egr valve took a dump. It has a horrible idle, and some rotten egg smell Bad thing is, I have had to drive it 3 days with it like that. No money to replace it right now, waiting for paycheck to come in. I'm going to buy the gasket for it, and remove the old one and clean it with carb cleaner like I was told..
    So my question is, will cleaning it work?
    Some dumb guy at autozone quoted me a price of $50 to $60 dollars for a new one. Well he was wrong... He checked to make sure it was the egr valve. it is...
    over $140
    I also heard they are a pain to take off, is that true?
    (note, i have never had a egr valve problem on any of my other cars).
    It also must of been mass egr valve failure day on the 24th, because 3 of my friends had the same problem.
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  2. #2 Re: UGH! Help with EGR valve...
    just take it completely off and you wont have any more problems with it.
  3. #3 Re: UGH! Help with EGR valve...
    I typically have a few laying around. Want one for $20 shipped via priority mail?
  4. #4 Re: UGH! Help with EGR valve...
    Charles City, IA
    I have one also that you could buy.
    SMGPFC Two Nipple General
  5. #5 Re: UGH! Help with EGR valve...
    Jun 2010
    Indy
    Will have to wait and see about buying one of yours... I can't tune the car if I were to just remove all of it.
  6. #6 Re: UGH! Help with EGR valve...
    Jun 2010
    Indy
    Think I might have fixed it!!? Cleaned it out today and put it back on, first time didn't seem like it worked. 2nd time starting it, seemed a little better than before, but not that great. I went to an event today, and the car sat awhile, when I started it she purrred like a kitten again. And the CEL went out while driving home. (I checked, it didn't blow). But I am getting one to set to the side just in case it just up and goes again. Going to the junkyard later on today and will get one out of there.
  7. #7 Re: UGH! Help with EGR valve...
    Pensacola, FL
    I on occasion would get an EGR code, and it was recommended to me to use a wire hanger fashioned in a way that you can scrape away some of the deposits in the line leading to the exhaust.
    When I did this I used a micro vacuum attachment ( to clean computers with) to suck up the deposits. Of course you could detach the line.....heh hindsight! Anyway, then I replaced the gasket and put the EGR back on.
    If I ever have problem with it again... I'll try the cleaner.
  8. #8 Re: UGH! Help with EGR valve...
    Jun 2010
    Indy
    Quote Originally Posted by Dermamorphic View Post
    Yea the cleaner did the trick for sure.. for now anyways
  9. #9 Re: UGH! Help with EGR valve...
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    Could you just take off the egr without a problem if you're not tuned?
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  10. #10 Re: UGH! Help with EGR valve...
    Jun 2010
    Indy
    Quote Originally Posted by Vlad0691 View Post
    From what I have read on this site, that is not a great idea. If you remove the whole egr system, you have to make block plates for the holes you have left open, and you will have to tuneyour car or else it will run like crap
  11. #11 Re: UGH! Help with EGR valve...
    Dacula, GA
    I figured as much lol. What exactly does the EGR do? Redirect your exhaust?
    R.I.P.
  12. #12 Re: UGH! Help with EGR valve...
    Jun 2010
    Indy
    Exhaust Gas Recirculation (EGR)
  13. #13 Re: UGH! Help with EGR valve...
    Charles City, IA
    It will not run like crap and the block off plates take like 2 min to make. You will just get a ses light. The egr valve lets exhaust back into the cylinder to take up space and cool the combustion chamber to help with Nox emissions.
  14. #14 Re: UGH! Help with EGR valve...
    Dacula, GA
    So what are the pros and cons of not having it?
    R.I.P.
  15. #15 Re: UGH! Help with EGR valve...
    SE Level Member Teardrop's Avatar
    Indiana
    Cons would be you would have to tune it, however THAT is accomplished.
    It could cause it to fail emissions if you are in an emissions county.
    Not sure of the pros, honestly it is probably best to just leave it intact.
    If an EGR is stuck open, it will idle like crap. If it is stuck closed, probably won't have too bad a problems.
    94 Grand Prix GTP, 3.4
  16. #16 Re: UGH! Help with EGR valve...
    Dacula, GA
    When I get a tuned PCM I'll probably take it out, block the holes, and request the tune to just emulate the EGR.
    R.I.P.
  17. #17 Re: UGH! Help with EGR valve...
    Charles City, IA
    pros and cons have been listed tons of times. All tuning it out is setting the code to no report.
  1. will car run without EGR Valve
    By kingsmurf in forum General Tech Discussion
    Last Post: 06-04-2010, 08:14 PM
  2. PVC Valve ??
    By TurboGTP in forum Turbo
    Last Post: 04-21-2010, 06:33 PM
  3. PCV Valve
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2010, 03:14 PM
  4. Pcv valve
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2010, 12:16 PM
  5. EGR Valve?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:24 PM
