Thread: Transmission
Results 1 to 15 of 15
  1. #1 Transmission
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Okay well my car was at a shop today and they said i need to get my transmission flushed because the fluid is kinda dark. I was reading on here though that its bad to get the trans flushed because it could free up stuff that is holding things together? should i just get the pan dropped and get the fluid changed or should i go for the full flush. BTW my trans slips very slightly into 4th and its been doing it for over a year.
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: Transmission
    just drop pan and replace the filter and fluid. dex 6 is what you want and about 7-8 quarts.
  3. #3 Re: Transmission
    Your tranny is going to die soon, fourth gear hub means things are not good in there.
    pan drop if anything.
    I'd rather save the $200 and put it towards the inevitable.
  4. #4 Re: Transmission
    Wilkes Barre, PA
    Yea. stupid thing. I keep it in 3 while driving around town but when im on the highway which is usually once a week ill put it into drive. I dont have the money for a new transmission right now either..
  5. #5 Re: Transmission
    Well first is for fourth to get worse and worse till it wont stay in fourth.
    Then give it some more time and those metal shavings will do more damage.
    Some go for a while without fourth.
    Others have it go very shortly thereafter.
  6. #6 Re: Transmission
    Wilkes Barre, PA
    well the slipping hasnt gotten any worse.. sometimes it wont even do it. And its been like that for a while now
  7. #7 Re: Transmission
    Then I'm not even sure your tranny is dying.
    Generall it slips in and out of fourth gear when it starts to go.
  8. #8 Re: Transmission
    Wilkes Barre, PA
    well when it shifts into fourth gear its almost like the car was put into neutral for like .3 seconds. Theres no loss of power though. And once its in 4th gear its completely fine. some people dont even notice it but i notice EVERYTHING haha.
  9. #9 Re: Transmission
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    TRIPLE EDGE TIME!!!! It's a celebration
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  10. #10 Re: Transmission
    300 ms shift time isn't great but it isn't terrible either.
    150 is a better time. but i've seen as high as 800 ms.
  11. #11 Re: Transmission
    Wilkes Barre, PA
    Lol well i never really timed it.. ill take a video tomorrow and post it up
    it shifts as fast as every other gear
  12. #12 Re: Transmission
    HUDSON
    I had the slight "overrun" going into OD also, all I did was raise the shift 3-4 pressure 3psi and it cleared it up nicely. With 150,000 miles on it, it still shifts good.
    I am thinking about getting one from a GT for the better gearing and rebuild it and have it for when the time inevitabley comes. Are the better gears worth it for a GTP, or does traction become a big problem?
  13. #13 Re: Transmission
    Traction is always an issue if you dont have a stiff suspension and sticky rubber.
  14. #14 Re: Transmission
    Wilkes Barre, PA
    well to get the psi raised i would have to find somebody who was a tuner right
  15. #15 Re: Transmission
    Quote Originally Posted by zildjian102 View Post
    correct
  1. Transmission
    By Minnesotawhite in forum General Tech Discussion
    Last Post: 03-02-2010, 10:39 AM
  2. transmission
    By joeyt637 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2009, 11:14 AM
  3. transmission value
    By M.$tErNeR in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2009, 07:41 PM
  4. transmission
    By jhlbigblock454 in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 02:40 PM
  5. Transmission goes bye-bye
    By FuglyGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-17-2009, 11:17 AM
