Thread: confused
Results 1 to 11 of 11
  1. #1 confused
    Joliet, IL
    ok so i thought fuel pump died when my car died on the road the other day but i filled the tank a lil more and got it to start it ran fine for awhile.....first time it died afr was 18 lean as shyt now that it starts again afr is at 10.5 and ltft's are at 25.9.....ive never seen that number before haha wtf is going on with my car bad fpr? car chugs and rough idles and if i give it gas it hardly goes.....im lost.....ii recently had to put in a fuel rail out of a jyard so im leaning toward fpr......insight anyone?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: confused
    have you been that low on fuel before?
    when was the last time you replaced the fuel filter?
  3. #3 Re: confused
    Joliet, IL
    yesterday and ive changed it 3 times since my e85 conversion
    00 Silvermist GTP
  4. #4 Re: confused
    Kansas
    You sure your tank is sealed up correctly? when mine wasnt the ltfts were all over the place.
    SOLD 1999 GT Silvermist TS
  5. #5 Re: confused
    Joliet, IL
    found the prob its the 02 sensor.....millis never leave 450 so its a bad sensor but the welder who welded the triangle shut on my pacesetters managed to weld the o2 sensor to the bung as well now what do i do this is a never ending string of BS
    00 Silvermist GTP
  6. #6 Re: confused
    Houston
    Welded the o2 sensor to the bung? Do you have a tuner? If so, cant you delete that sensor?
  7. #7 Re: confused
    Joliet, IL
    no its the upper o2 which the engine uses for fueling which would explain my afr issue........now i just gotta find out how to get this out or just buy some speed daddys and a new o2,,,,,
    00 Silvermist GTP
  8. #8 Re: confused
    Chilliwack BC
    a torch. and alot of paitience you might get it out...if it's actually welded onto the bung......ick
  9. #9 Re: confused
    Joliet, IL
    got it out and replaced it still nothing.....now i noticed my exhaust being VERY moist and the car is running hella rich hope i dont have a blown head gasket time to check the oil......
    00 Silvermist GTP
  10. #10 Re: confused
    Chilliwack BC
    Quote Originally Posted by BoostJunki3 View Post
    *fingers crossed*
  11. #11 Re: confused
    Joliet, IL
    AHAH found it bad lq4 maf......phewww
    00 Silvermist GTP
  1. new and confused
    By kellyreap in forum General Tech Discussion
    Last Post: 03-17-2011, 08:35 AM
  2. Ok, now I'm confused.
    By Bluemagic in forum General Tech Discussion
    Last Post: 12-17-2010, 12:30 PM
  3. im new and confused
    By onetyme77 in forum Introductions/Noob Questions
    Last Post: 11-28-2010, 04:03 PM
  4. New and confused.
    By 99p0ntiac in forum Introductions/Noob Questions
    Last Post: 04-25-2010, 03:40 PM
  5. Confused!
    By tyno59 in forum Visual/Body Modifications
    Last Post: 10-29-2009, 09:17 PM
