Thread: car is eating serpentine belts?
Results 1 to 14 of 14
  1. #1 car is eating serpentine belts?
    Feb 2010
    USA
    when i bought my GTP the serpentine belt around the alternator was torn on the last like 1 rib of the belt ( side closest to the motor ) , so i had a shop replace the belt for me , now like 3 days later the belt is torn in the same spot?? something is chewing the edge of the belt off to the point of ripping one rib off the belt, just giving it a visual insp from up top i cant see where it would be catching and tearing it at but its not tearing it just from start up cause i had checked the belt after i got home that day and it was fine... so after putting about 100 miles on it its torn again? any ideas?
  2. #2 Re: car is eating serpentine belts?
    Apr 2009
    stockton ca
    somethings not aligned right maybe a/c compresor or and idler pulley
  3. #3 Re: car is eating serpentine belts?
    Feb 2010
    USA
    yeah i dont know, if something wasnt aligned right wouldnt it tear it at first start up?
  4. #4 Re: car is eating serpentine belts?
    Feb 2010
    columbiaville, mi
    Usually the tensioner is faulty which causes the belt to slip sporadically. I'd replaced the tensioner or at least get it checked. It should take a lot of torque to remove the belt with th etensioner tool or ratchet head.
  5. #5 Re: car is eating serpentine belts?
    Feb 2010
    USA
    Quote Originally Posted by angelj View Post
    im gonna check it out, thanks!
  6. #6 Re: car is eating serpentine belts?
    Feb 2010
    USA
    Quote Originally Posted by schroedes View Post
    well its easy, your car is ****ing old, face it, get a job and buy a new one
    damn! were did that come from? dont think i said anything about having to buy another belt... im not just gonna put another belt on without fixing the problem. maybe thats how you work but not me..
  7. #7 Re: car is eating serpentine belts?
    Feb 2010
    USA
    well after looking at the pullies today im thinking the alternator pulley is a little bit narrower then the others. im not sure if its the factory one or not, says delphi automotive on it. thats GM right? the alt pulley measures exactly 1" wide were the others measure a little bit wider like 1-1/8. are there any other ALT's that could fit the GTP that have a slightly diff pulley on it or ??
  8. #8 Re: car is eating serpentine belts?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    BUMP, my buddy has the SAME EXACT PROBLEM, that I'm trying to diagnose! Any resolution to this?
    For all your 3800 needs:
  9. #9 Re: car is eating serpentine belts?
    Quote Originally Posted by copgtp View Post
    put a metal straight edge across the pulleys to see if they line up, i swapped out a power steering pump on my truck, and i had to pull the pulley off to put on the new pump, i was off by 2 8th's of a inch, the belt shredded and it hit the oil cooler lines and pulled them from their clips, then they dragged on the balancer and cut apart and leaked , one job turned into 2 real fast. (i was stuck doing this job on new years eve in my drive way during a snow storm, freezing my ass off and had to get back on the road because i was snow plowing, 100 bucks an hour lost every hr i was off the job, the belt shredded the next day and the lines cut the day after, nightmare)
  10. #10 Re: car is eating serpentine belts?
    Charles City, IA
    Is there any build up on the smooth pullies?
    SMGPFC Two Nipple General
  11. #11 Re: car is eating serpentine belts?
    SE Level Member Paul79UF's Avatar
    Florida
    Another thing I would check is whether the idler and tensioner pulleys spin freely.
    My car tore up half a serpentine belt on the highway. When I took off the old belt, I spun all the pulleys by hand.
    Both the idler and tensioner pulley didn't spin easily. I'm guessing that didn't help the situation. So I replaced them both.
    You can change out the pulleys and belts yourself. All you need is a 15mm socket with a long handled ratcheting wrench.
  12. #12 Re: car is eating serpentine belts?
    Orange County, NY
    Thanks for the information guys.
    The belt did shred before I put the new power steering pump on.
    I will check with with a straight edge on the pullies.
    The belt is shredding from the inside, not the outside..... No build up on any of the smaller pullies.
  13. #13 Re: car is eating serpentine belts?
    small world here, i know who's car you are working on, lol my brother works with sean over at tractor supply, big hairy Ted is my brother. i was talking to him and he was telling about the problems he was having, so i put 2 + 2 together.
  14. #14 Re: car is eating serpentine belts?
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    I know a buddy of mine was having this problem but his was due to having build up on the tensioner pulley and as soon as he replaced that problem solved
  1. 2003 3.1L GP - When to change belts?
    By bxfl in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-14-2010, 12:55 PM
  2. help please with serpentine
    By tsoupeis in forum General Tech Discussion
    Last Post: 11-07-2009, 06:11 PM
  3. Eating belts!?!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 12:10 PM
  4. Hoses VS Belts.
    By GTPRiley in forum The Rant Forum
    Last Post: 01-05-2009, 05:44 PM
