Thread: Shift Points
Results 1 to 8 of 8
  1. #1 Shift Points
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    According to my tach, my shift points are at 5500rpm. Stock. Should I go any higher once I get headers on? If so, how much higher? Or, is there no point revving past 5500rpm?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  2. #2 Re: Shift Points
    Akron Ohio
    NO... you need cam, rockers, tune, springs, timing chain, Alot before you think about changing shift points.
  3. #3 Re: Shift Points
  4. #4 Re: Shift Points
    So, then why are your shift points stock...and you have a Intense PCM? That doesn't make sense to me...they should be set at either 5800 or 6K.
  5. #5 Re: Shift Points
    Charles City, IA
    He probably chose to have the shift points left stock as an option.
    SMGPFC Two Nipple General
  6. #6 Re: Shift Points
    5500 is stock?
    I thought it was closer to 5800
  7. #7 Re: Shift Points
    5500 is stock?
    whatever your tach reads is always a couple hundred rpm over what the actual shift point is.
  8. #8 Re: Shift Points
    Dec 2008
    Alabama
    I had them leave the stock shifts since I've heard there's no power over 5500. Thanks guys.
  1. Shift points and Mph?
    By GTP4 in forum PCM Tuning
    Last Post: 11-11-2009, 12:59 PM
  2. TPS Replacement - Shift points?
    By shadow83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 11:48 AM
  3. Shift Points
    By RicerKiller in forum PCM Tuning
    Last Post: 03-24-2009, 01:19 AM
  4. Shift points
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-28-2008, 02:26 PM
  5. WOT Shift Points...RPM/MPH
    By japslpr in forum PCM Tuning
    Last Post: 02-04-2008, 07:12 PM
