My right rear tail light is dead. Probably from the condensation issue. The question i am looking for help with is this... am i going to be doing a simple bulb fix or fuse fix or am i going to be buying a whole new set up for my tail. Thanks.
One of my tails fills with water and the bulb aslpoded.
just swapped the reverse light with the tail light for the time being.
new bulbs did the trick, old ones were soaked. now any ideas on how to seal this pos light up so this doesnt happen? i see a bunch of guys talking about drilling hold in the light to allow water to run out.
I masking taped mine off and put a bead of black rubberized caulking around the edges and the inside also....and drilled 2 holes in each corner of the light ...good so far
