Thread: thermostat swap
Results 1 to 20 of 27
  1. #1 thermostat swap
    Jun 2010
    denver
    hey guys new here i got an 06 gp sc i just picked up a 180 degree thermostat was wondering if there was a write up anywhere that i might have missed or give me sime advice on how to swap thanks for any info is apreciated
  2. #2 Re: thermostat swap
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    easiest mod ever... just look at it and folow your upper radiator hose back to the motor... theres a metal piece it clamps to and two bolts holdin it down take those bolts out and pay attention to how the origional was in there, replace and put back together
    btw a pcm with altered fan temps is a great way to actually take advantage of it too... otherwise youll have a wide swing on the temps when not moving. no biggie though and no reason to be concerned
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: thermostat swap
    MA
    Quote Originally Posted by Kejross View Post
    all that typing for nothing? you bastardo lol... x2 on pcm, theres nothin wrong with running without it, itll just be more effecient with it
    SMGPFC Member #9
  4. #4 Re: thermostat swap
    Feb 2010
    Oklahoma City, OK
    beat ya! ha!
  5. #5 Re: thermostat swap
    MA
    beat ya! ha!
    yeah typing with a cig in one hand and a cast on the other is a b!tch lol
    SMGPFC Member #9
  6. #6 Re: thermostat swap
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by SilvaMan61 View Post
    no excuse i just had a plate and 5 screws put in my shoulder, its like the worlds most useless limb right now and i been drinking beer and eating popcorn with the other
  7. #7 Re: thermostat swap
    MA
    the swap is really simple and straight forward. I did it on my 99 gtp with no mechanical experiecne at all. it may be slightly differnt on yours but should be similar.
    all you have to do is follow the larger radiator hose towards the engine (driver side on my 99, should be on yours too), you should see a metal housing thats somewhat bell shaped, this is the t stat housing. i belive there were just 3 or 4 bolts holding it in place. remove these and lift up the housing ( have a good sized bowl or something ready because coolant will spill out, also GIVE THE ENGINE PLENTY OF TIME TO COOL the sh!t will be HOT otherwise.) now you should see the t stat sitting there. just pull and replace. reinstall housing and your done.
    SMGPFC Member #9
  8. #8 Re: thermostat swap
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    I would like to do that to my 97, should be the same right? what kind of thermostat do I need to get? cause there are 2 types (if I remember good) I want to change it because lately, my car temperature stays on almost 210 mark
  9. #9 Re: thermostat swap
    MA
    its the same deal dude, what two types are you refering to?
    SMGPFC Member #9
  10. #10 Re: thermostat swap
    Feb 2010
    Oklahoma City, OK
    oh and when your done open that brass screw on top to bleed out any air. just leave it open til it flows solid coolant...
  11. #11 Re: thermostat swap
    Charles City, IA
    Its 2 bolts, get a 180* tstat.
    SMGPFC Two Nipple General
  12. #12 Re: thermostat swap
    yeah that! I heard of a 180 and 195? thats why I said two types
  13. #13 Re: thermostat swap
    MA
    yupp 180 es goodo
    SMGPFC Member #9
  14. #14 Re: thermostat swap
    195 for any car with a pulley larger than a 3.4 or N/A..............
  15. #15 Re: thermostat swap
    SE Level Member rmil03's Avatar
    Jun 2010
    jersey
    and whats this do..... sorry im just being dumb right now, does you engine run cooler with a smaller tstat in it?
    '01 gpgt, tinted tails, k&n custom intake, lime green engine bay, straight pipe exhaust, gold/black interior. dirrrrrtydir
  16. #16 Re: thermostat swap
    uh no? either its the right size or its the wrong size.
    Since you're stock, run the stock temperature t-stat.
  17. #17 Re: thermostat swap
    SE Level Member GTX98's Avatar
    Frankfort
    Does changing out the t-stat make a noticeable difference for performance?
  18. #18 Re: thermostat swap
    hells to the no!
    Stick with stock till youre running something more extreme than a 3.4 setup.
  19. #19 Re: thermostat swap
    Mattoon, IL
    Not to hijack the thread...but can somebody tell me if the tstat on an 03 SE sits on it's side as opposed to the traditional upright position?
  20. #20 Re: thermostat swap
    Charles City, IA
    yup they are a pita on the 3.1,3.4
  1. Thermostat...
    By TorqueAutoMotiv in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-13-2009, 11:20 PM
  2. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
  3. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  4. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  5. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
