Thread: problem with headlights and d.i.c
Results 1 to 10 of 10
  1. #1 problem with headlights and d.i.c
    SE Level Member joelnv02GTP's Avatar
    alberta, canada
    recently i went and started my car and for some unknown reason my headlights and dic just shut off? I have no idea what caused this but after a few minutes all was fine, so i thought. As im driving down this dark backroad it all shuts off again and now im doing a 120kmh and everything went black. Does any1 have any ideas as too what is causing this?, or how i may go about fixing this. It just seems very unsafe too me. O and no i have not done any work to my car recently as im in camp. Any input would be greatly appreciated, thanks in advance Joel
  2. #2 Re: problem with headlights and d.i.c
    alberta, canada
    I almost forgot when lights and dic shutoff the heater and my cd player also shut off. Its like everything on that realy or fuse jus dies and then comes back to life
  3. #3 Re: problem with headlights and d.i.c
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    OMG! mine does the same thing, except its only when i turn the heater on, or the blower. im glad its not only my car
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  4. #4 Re: problem with headlights and d.i.c
    alberta, canada
    ya now to just figure out whats causing it. and mine is doin it now to when i turn on heater.
  5. #5 Re: problem with headlights and d.i.c
    WI
    Experiencing a similar issue with my 2002. Car starts fine in the morning. Drive 5 minutes, drop kids off at school, start car back up and DRL and blower don't work. Drive for a few miles and they come back on. Things that come to mind are fuse issue, battery or alternator??
  6. #6 Re: problem with headlights and d.i.c
    WI
    after doing a little more looking around sounds like it could be the ignition switch.
  7. #7 Re: problem with headlights and d.i.c
    Nov 2010
    south east AZ
    ignition switch, really? thats wierd
    01 T/A WS6-SOLD
  8. #8 Re: problem with headlights and d.i.c
    O!..NEB
    too bad people that actually know what it is dont speak up...ive had this problem forever too.. after awhile it just stops..but now my dic doesnt light up at all and my blower resistor went out..only works on high. but the dic is still working i can tell because when light is on it you can still see it, it just doesnt light up. but when i turn on the blower to high it will stop working, it will just keep going on and off yet all my headlights will work
  9. #9 Re: problem with headlights and d.i.c
    WI
    Finally too my car in for these symptoms. It indeed was the ignition switch. After getting it replaced, all of my symptoms have been corrected. If you are experiencing similar symptoms I am willing to bet it is the ignition switch.
  10. #10 Re: problem with headlights and d.i.c
    SE Level Member jmt455's Avatar
    SE Michigan
    It's the ignition switch. The contacts get so badly scorched they eventually fail.
    It usually starts with DIC/Blower speed/AC problems. In my case, the DRL relay was also going crazy.
    I found two excellent links for this issue:
    1. Diagnosis here:Sparky's Answers: 2002 Pontiac Grand Prix Blower Inoperative, Erratic
    2. Replacement procedure here:Sparky's Answers: 2002 Pontiac Grand Prix, Changing The Ignition Switch
    If you find these liks helpful, I'm sure "Sparky" would appreciate any contribution you could afford. (No, I am not Sparky, nor am I affiliated with the site.)
    Ignition switch - GM Delco part number:26068757
    All of my little electrical gremlins completely disappeared after replacing the switch.
    To get the longest possible life out of the new switch, you could also install the Plug-N-Play ignition switch bypass relay.
    Instructions/Sticky here: http://www.grandprixforums.net/ignition_bypass.php
    Hope that helps!
    JoeT
    83 Bonneville wagon
    08 G8 Base
  1. headlights
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 01-17-2011, 09:32 PM
  2. HID Headlights
    By ljmonnin12 in forum Visual/Body Modifications
    Last Post: 11-25-2010, 09:37 PM
  3. HID Headlights
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 12:30 AM
  4. Need new headlights
    By maddog39 in forum Visual/Body Modifications
    Last Post: 09-29-2009, 07:04 AM
  5. 04+ headlights
    By Clar2478 in forum Visual/Body Modifications
    Last Post: 01-10-2009, 10:30 AM
