Which ones the best out there for the price.. Looking to get a good one for tuning and to keep in my car. Thanks.
BTW - yes ive searched alot but get a lot of people going different ways with widebands.
Our Edelbrock is the cheapest one around:
Gauges : Whiplash Intense Performance, your Performance Parts Warehouse
I currently use the dual version of this one:
Fast Single Digital Air/Fue ratio meter [Comp-170401] - $339.95 : Whiplash Intense Performance, your Performance Parts Warehouse
As I said in the last thread about this.....
One you like the look off, and if you so desire, one you can log with a data logger.
That edelbrock one starts at 12 afr and goes up. Wouldn't work in our application or boosted application.
I use a plx. I would either get the aem or a plx. Two of the most common wideband used in wbodys so if you have an issue or need help on finding the formulas to log it, you shouldn't have. Problem. The lc1 is good if your moving it from car to car, but need open air calibration and may or may not come with the guage.
Do you have a tuner then? Or do you need one with a stand alone logging system. Any wideband with a 5v out can be logged with a tuner.
If you dont run the egr system you can wire any 5v out wideband by following my writeup.
All depends on how you run the wiring, my would be kinda a pita because I tucked it all away.
Got mine on ebay for 250 something I think amazon has them cheaper.
