Thread: Need help-Mass Air Flow Sensor '99
Results 1 to 16 of 16
  1. #1 Need help-Mass Air Flow Sensor '99
    PA
    Just joined the site I need some help with a 1999 prix. 3.8L V6 engine no supercharger. Had the car diagnosed and the mass air flow sensor is bad and needs to be replaced. Dealership wants $600 for the job and I have seen a couple write-ups online about it being an easy change. I figured I would join this forum and see if anyone has done this before and if so how difficult is this job? I'm sure this is my first of many posts to come since the car is and has been falling apart for the past 4-5 years. Sad but true, they are nice looking rides but just don't seem to hold up very well.
    Thanks in advance for the help
  2. #2 Re: Need help-Mass Air Flow Sensor '99
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    is a very easy job. all you do is remove two bolts that hold it down, remove sensor, install new one and finally put the two bolts back on. most of the time its a small torx bit with the security nipple in the center.
  3. #3 Re: Need help-Mass Air Flow Sensor '99
    Dec 2008
    Lawndale, CA
  4. #4 Re: Need help-Mass Air Flow Sensor '99
    i bet your local local junk yard sells them used for about 40 bucks with a 30 day warranty, new they can be as much as 200.00, thats what i did.
  5. #5 Re: Need help-Mass Air Flow Sensor '99
    PA
    thanks for the info, this is a big help. Still don't get how the dealership can rip you off for $600. Unbelievable.
  6. #6 Re: Need help-Mass Air Flow Sensor '99
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by msh227 View Post
    Easy job, may need special security bits if you have the torx with teh post in the middle. A whole set at harbor freight is like 3-4 bucks though. Its right on top of the throttle body, has 2 screws and a 3 wire plug. And I have a MAF out of a 02 GT if you need the part as well... Just let me know.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  7. #7 Re: Need help-Mass Air Flow Sensor '99
    Quote Originally Posted by Kejross View Post
    or if you are cheap, like me, u can use a grinder to cut a slot across the torx and use a flat head screwdriver. just use a thin cutting disk.
  8. #8 Re: Need help-Mass Air Flow Sensor '99
    Feb 2010
    Oklahoma City, OK
    Holy damn I waited too long... lol Didnt realize everyone else had already posted
  9. #9 Re: Need help-Mass Air Flow Sensor '99
    Jersey
    its a t20 torx bit. I have a good 99 gt maf sitting around, if you want it let me know. I'll sell it to you for cheap.
    edit: i think its a security/torx bit
    16' wrx sti- stock
  10. #10 Re: Need help-Mass Air Flow Sensor '99
    SE Level Member 1999GrandPrix's Avatar
    Oct 2011
    South Carolina
    hey 99prixgt or pure2sin, still have the stock oem maf for sale? im interested in it. i also have a 99 gt lemme know?
  11. #11 Re: Need help-Mass Air Flow Sensor '99
    Minnesota
    I just pulled mine off my care for my top swap. Since I am running a LQ4 I won't need it. If you would like to buy mine PM me. I don't know where you are going to find one for $30 lol ZZP sells them for like $160 or something.
  12. #12 Re: Need help-Mass Air Flow Sensor '99
    New-Brunswick, Canada
    Can a MAF sensor from a non supercharged grand prix be used on a GTP? I have a 2002 btw. Thanks guys, cheers!
  13. #13 Re: Need help-Mass Air Flow Sensor '99
    yes if the part # is the same. the one im using is off a n/a motor.
  14. #14 Re: Need help-Mass Air Flow Sensor '99
    Depending on the year...
    97-98 MAF's are the same N/A and S/C.
    99-03 MAF's are the N/A and S/C also...
  15. #15 Re: Need help-Mass Air Flow Sensor '99
    Don't revive dead threads to ask brand new questions.
    To the OP if you're still around.... Post in the correct section.
  16. #16 Re: Need help-Mass Air Flow Sensor '99
    Thanks guys, indeed my intent is not to revive old threads, but for some new members walking on unfamiliar territory, its hard to navigate the site, and when time is of the issue, you hope someone can give you a quick answer.
    I noticed on my MAF sensor its written AFH50M-05(if I read it right) and from what I can tell its a A1 Cardone type. If this is the case then the previous owner must have replaced it before, cause I would imagine stock from the factory it would be a GM/AC Delco? Anyways, thanks again guys, I can now go to my mechanic and get one off a 99 non-supercharged engine from his yard for 40 bucks, cheers!
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. mass air flow sensor compatiblity
    By daveydavido in forum General Tech Discussion
    Last Post: 02-24-2010, 03:10 PM
  3. P0102: Mass or Volume Air Flow Circuit Low Input
    By anicolay in forum General Tech Discussion
    Last Post: 04-30-2009, 12:59 PM
  4. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
  5. Mass air flow sensor
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2008, 01:36 PM
