Thread: Mass Air Flow Sensor
Results 1 to 2 of 2
  1. #1 Mass Air Flow Sensor
    PA
    I'm sure there are a bunch of questions and threads about the mass air flow sensor. I have one final question dealing with them. If I remove the sensor and do not replace it what will happen? Can I drive without the sensor? Thanks.
  2. #2 Re: Mass Air Flow Sensor
    You'd have a giant hole in your TB. You are going no where.
    Unplug it, the pcm will default to using preprogrammed tables. You can drive, but be nice to the car. It's running off tables of general data, not actual data.
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. Need help-Mass Air Flow Sensor '99
    By msh227 in forum General Tech Discussion
    Last Post: 03-09-2012, 11:54 PM
  3. mass air flow sensor compatiblity
    By daveydavido in forum General Tech Discussion
    Last Post: 02-24-2010, 03:10 PM
  4. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
  5. Mass air flow sensor
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2008, 01:36 PM
