Thread: Intake and Plugs
Results 1 to 20 of 24
  1. #1 Intake and Plugs
    GTX Level Member Confusingboat's Avatar
    Minnesota
    So I just did my intake today (bolted a big ass Spectre filter onto the MAF) and installed new plugs, and they were a pain in the mother****ing ass. Is there any "easy" way to do plugs on these damn things?
    Btw, the new intake makes my car sound like it's angry and hungry for rice lol.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  2. #2 Re: Intake and Plugs
    easy way to do plugs: install headers, remove boot protectors and leave them off.
  3. #3 Re: Intake and Plugs
    Minnesota
    Lol thanks I'll remember that.
    2015 Evo MR
  4. #4 Re: Intake and Plugs
    Remove the extra brackets in the back of the motor (engine hoist and engine cover brackets).
    Then stop being a *****, man up and stop whining about a scratch.
    You could also leverage the motor forward by unhooking the driverside dogbone and using the second hole in the passenger side one to hold the motor.
  5. #5 Re: Intake and Plugs
    Charles City, IA
    Easiest way to do plugs on any engine is to pay someone else.
    SMGPFC Two Nipple General
  6. #6 Re: Intake and Plugs
    a scratch is a sign that you did some manual labour for once.
  7. #7 Re: Intake and Plugs
    I live here. TLSheff's Avatar
    By boot protectors im assuming you mean the metal ones right????
    and thusly install the mesh boot covers to keep them from getting hot from the headers or just leave it be???
  8. #8 Re: Intake and Plugs
    I have MSD wires...with headers...I'll prolly get some PRJ's next year because mine are getting kinda junky...just dirty more than anything...a few burns here and there. Never had any issue though.
  9. #9 Re: Intake and Plugs
    GT Level Member starscream5000's Avatar
    Kentucky
    They are a pain to do the first time because the wires like to seize to the plugs. Once you get them off the first time, put a lot of dielectric grease into the boot and you'll not have any issues next time around. If you are having a hard time getting the plugs out, or even getting to them, then you either have really big arms, or short ones. I have no problem getting to the back plugs and removing them.
    I don't need to unhook the dogbones, I don't need to take any covers off, nothing.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  10. #10 Re: Intake and Plugs
    Florida
    Way i've always done it, (with both manifolds and headers) is to just yank the front out, easy enough, and on the rears, go under where the EGR is with a wobble joint and an extension or 2, makes life easy.
    then again you may bust the **** out of your hand with the wobble joint....
  11. #11 Re: Intake and Plugs
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I can change my plugs in 10 min or less. I dont see whats so hard here? I dont even rotate the engine forward
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: Intake and Plugs
    Minnesota
    My plugs had never been done before so they had been on there for 6 years through winters and 130k miles lol. I put lube on the new plugs so I'm assuming I won't have problems next time around. The plugs themselves came out fine, it was just the boots that were being a mother****er.
    2015 Evo MR
  13. #13 Re: Intake and Plugs
    headers make plug changes easier.
    by far.
    and leaving those stupid metal things off helps a bunch as well.
  14. #14 Re: Intake and Plugs
    Kentucky
    Quote Originally Posted by Confusingboat View Post
    You'll be fine the next time around. Change them more often
  15. #15 Re: Intake and Plugs
    Minnesota
    More often. So like every 30k miles?
    2015 Evo MR
  16. #16 Re: Intake and Plugs
    Topeka, KS
    Something like that
  17. #17 Re: Intake and Plugs
    Hagerstown,Md
    I change mine about every 5K miles
  18. #18 Re: Intake and Plugs
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Quote Originally Posted by 01gpgt01 View Post
    How come so often? What kind are you running
  19. #19 Re: Intake and Plugs
    youre supposed to run copper plugs for around 10k miles. i always just changed mine every 2-3 oil changes.
  20. #20 Re: Intake and Plugs
    Minnesota
    How long for platinum? Google suggests every 100k miles but that seems ridiculous.
    2015 Evo MR
  1. NGK TR6 plugs
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2010, 01:36 PM
  2. plugs
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 07:37 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. TRI-55X Plugs=bad KR for my car?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2008, 04:44 PM
