Thread: intake
Results 1 to 11 of 11
  1. #1 intake
    SE Level Member tssmokefangtp's Avatar
    lake wylie s.c
    i got some supplies for my intake ..do i need 3"coupler or 4 ....and do i need a 45 angle pipe 4" or 3" i hear 2 differnt stories..plz help i got a 4"coupler and a 3" pipe so what do i need to do ...take the cupler back and get a 3" or take the pipe back and get a 4" ...
    smokegtp
  2. #2 Re: intake
    SE Level Member xsvtank's Avatar
    NJ
    take the pipe back and go with the 4 in
  3. #3 Re: intake
    Charles City, IA
    get a 3.5" inlet filter and put it on the throttle body.
    SMGPFC Two Nipple General
  4. #4 Re: intake
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Where do you put the AIT sensor if the filter is slapped directly on the TB?
  5. #5 Re: intake
    Charles City, IA
    Zip tie it somewhere close to the filter.
  6. #6 Re: intake
    Donating Users
    Parma, Ohio
    yeah i was running the filter right of the throttle body...just had my sensor zip tied on top of the filter
    2003 Subaru Impreza WRX
    2008 Saturn Aura
    2000 Bright Red GTP coupe. RIP 11/6/11
  7. #7 Re: intake
    GT Level Member starscream5000's Avatar
    Kentucky
    You hear about 3" pipes because those are geared for '04 and up cars. They have the air flow sensor separate from the throttle body. The housing for the sensor is 3" in diameter, so it's kinda pointless to do anything larger on that generation of GP.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  8. #8 Re: intake
    Willoughby, Ohio
    4in coupler, 4in pipe, 4in filter, drill hole for IAT... done.
  9. #9 Re: intake
    Trevose, PA
    Do you know what size drill bit you used to make a snug fit?
    I don't want to drill unless I know the exact size I need yah know
  10. #10 Re: intake
    Jul 2008
    sumter,south carolina
    get a rubber grommet to put the iat in...
    02 GTP with mods 05 GP for DD
  11. #11 Re: intake
    Willoughby, Ohio
    i used a small one and kept enlarging the hole till the proper size so i was exact
  1. New Intake
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2009, 01:01 AM
  2. 3.1L Intake
    By josemolina2008 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-26-2009, 02:32 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. Intake
    By bct717 in forum 04+ Specifics
    Last Post: 03-22-2009, 09:41 PM
