Thread: Please Help!!! GTP surging idle
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Please Help!!! GTP surging idle
    utah
    Hey everyone, i'm new to this forum but i've read great stuff from all you guys i hope you can help.
    First of all i have a 98% stock 98 GTP with 185k i've replaced the crankshaft sensor, MAF,Plugs and wires, K&N air filter, Thermostat, Battery and all the fluids (except the super charger oil, going to do soon).
    on start up things go great. It fires up right off and the tach goes up to about 1100 rmps but then it starts to drop very slowly until it reaches about 500-700 rpms then it just sits there ROUGHLY idling. The needle on the tach barely moves up or down but hardly noticeable just bouncing from 600-800 rpms but its almost like the car is shaking slightly. i've been running low octane fuel for about six months but recently switched back to 91 (after reading this forum!).
    All symptoms are GONE above 1100 rpms and everything runs great except for my idle, it's awful. i cleaned the sensors on the TB with TB cleaner and replaced the MAF and i don't know where to go next!?
    ps. no codes at all cleared them after replacing the MAF and nothing so far.
  2. #2 Re: Please Help!!! GTP surging idle
    toss a scanner on it and see what codes or misfires you get. That'll tell you where to concentrate your efforts.
  3. #3 Re: Please Help!!! GTP surging idle
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Idle misfires are not uncommon on these cars when theres no load on the engine (in park or neutral). If its bouncing from 600-800 rapidly though Id be looking for a possible vac leak
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Please Help!!! GTP surging idle
    utah
    thats what i was leaning towards, how do i check for vac leaks? and have you ever used seafoam? i hear it works wonders?
  5. #5 Re: Please Help!!! GTP surging idle
    Pennsylvania
    Check all of your vacuum hoses and connections. Could be a that something disconnected/dry rotted/pinched/cracked, etc.
  6. #6 Re: Please Help!!! GTP surging idle
    GT Level Member starscream5000's Avatar
    Kentucky
    My 06 malibu and 05 GTP both display the same idle issues as what you describe. Both cars a very well kept and have properly gapped plugs and new wires, they still have a slightly stumbling idle. I think it's just that these cars and other GM V6's are prone to an idle misfire condition like mentioned earlier.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  7. #7 Re: Please Help!!! GTP surging idle
    utah
    dang not what i wanted to hear i did a seafoam tonight and changed the fuel filter cleaned the plugs and it worked great car runs amazing! just idles like sh**!!!! im thinking about taking it to the dealer to get it tested but its like $75 just for a diagnostic!!!
  8. #8 Re: Please Help!!! GTP surging idle
    utah
    no luck for the vacuum leaks but i found a cracked tube on my SC! i replaced it tonight now my boost feels amazing. but no luck on the idle. i hear a hiss but i looked for hours with no luck. any good methods of searching? besides like a smoke machine (way expensive!)
  9. #9 Re: Please Help!!! GTP surging idle
    Hagerstown,Md
    Quote Originally Posted by Damon318 View Post
    Water bottle with a high soap/water mix. spray it around the lower intake/throttle body/Sc/Injectors and see if you hear it get sucked in or see it bubble
  10. #10 Re: Please Help!!! GTP surging idle
    Kentucky
    Carb cleaner sprayed around suspect vacuum leaks will raise the idle temporarily if sucked into the motor...
  11. #11 Re: Please Help!!! GTP surging idle
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    look into your idle air control valve after you have went over the basics
  12. #12 Re: Please Help!!! GTP surging idle
    utah
    Alright i feel realy stupid asking this but i sprayed the carb cleaner and my idle went right back to normal so i figured im on the right track it a vacuum leak! i thought this was great news until i traced it down to a machined whole on the engine side of the TB( !?) Im no motor head and have no idea what this whole is? its sucking in air and when i spray it with the carb cleaner my rpms go right to normal? i dont know what this means but i dont think its a vacuum hose leak? maybe check the other sensor on my TB?
  13. #13 Re: Please Help!!! GTP surging idle
    utah
    alright im at a total loss! i replaced my plugs wires maf iac fuel filter oil and filter did a sea foam clean checked for vac leaks tore apart my TB and cleaned it from top to bottom cleaned all the new sensors let my car run with out the maf (still a problem so its not the new maf) put in new gas and injector cleaner checked my throttle positioning and i still have a horrible idle below 1000 rpms! and now when im driving at highway speeds and let off the throttle my rpms drop to 1000 and then bounce back up to around 2.5!? any help at all would be greatly appreciated.
  14. #14 Re: Please Help!!! GTP surging idle
    Kentucky
    Oh my, test, don't guess man. Did you ever fix the hole that you mentioned in your previous post? Why don't you post a pic of the hole that you are talking about. Most of us work better when we can see what you are talking about.
  15. #15 Re: Please Help!!! GTP surging idle
    Take a pic of that hole and show it to us. There should be no hole in your TB that you can spray and have it change idle. There's only one vaccum port on the TB and it should be going to the evap.
  16. #16 Re: Please Help!!! GTP surging idle
    utah
    ill go take a pic right now its a machined hole i thought it was to the iac or something but like i said im just learning i really appreciate the help guys!
    its on the sc side not the TB my mistake
  17. #17 Re: Please Help!!! GTP surging idle
    utah
    this is the whole and if i spray it my car idles perfect. its on the supercharger side but i looked and it connects to the TB i thought it was something to do with the iac for adding extra air if there was a problem but thats a shot in the dark?
    any ideas?
  18. #18 Re: Please Help!!! GTP surging idle
    utah
    [IMG]file:///C:/Documents%20and%20Settings/Owner/Desktop/Music/Photo-0581.jpg[/IMG]
  19. #19 Re: Please Help!!! GTP surging idle
    Try loading it to photobucket, image shack or someplace like that. Should work for ya that way.
  20. #20 Re: Please Help!!! GTP surging idle
    Kentucky
    My phone is not bringing up a pic, and my work computer's firewall is blocking the image hosting site as well. I can't help you out with the picture man, sorry
    You are changing too many variables at once. Test one thing at a time. You should put your old sensors back on and make sure the tps that you messed with is set back to the same position that it was in before you messed with it.
  1. Surging idle when warm
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 10:21 AM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. Surging idle under normal acceleration
    By billy8380 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2010, 10:36 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
