Thread: gtp start sputter
Results 1 to 12 of 12
zildjian102 gtp start sputter 06-12-2010, 10:33 PM
zildjian102 Re: gtp start sputter 06-17-2010, 06:35 PM
QUICKSILVER462 Re: gtp start sputter 06-17-2010, 08:11 PM
TheOtherNick Re: gtp start sputter 06-17-2010, 08:13 PM
zildjian102 Re: gtp start sputter 06-17-2010, 10:28 PM
QUICKSILVER462 Re: gtp start sputter 06-18-2010, 06:47 AM
zildjian102 Re: gtp start sputter 09-27-2010, 08:08 PM
01gpgt01 Re: gtp start sputter 09-27-2010, 08:22 PM
zildjian102 Re: gtp start sputter 09-27-2010, 09:36 PM
zildjian102 Re: gtp start sputter 10-09-2010, 10:04 AM
TheOtherNick Re: gtp start sputter 10-09-2010, 10:47 AM
zildjian102 Re: gtp start sputter 10-09-2010, 11:08 AM
  1. #1 gtp start sputter
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    YouTube - Grand Prix GTP sputtering start
    Anybody know why it does this? it starts like that sometimes and then it idles perfectly
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: gtp start sputter
    Wilkes Barre, PA
    anybody?
  3. #3 Re: gtp start sputter
    HUDSON
    leaky injector?
    Does it do it if you shut it off, and the restart in like 30 seconds?
  4. #4 Re: gtp start sputter
    Charles City, IA
    I bet on a fuel pressure regulator.
    SMGPFC Two Nipple General
  5. #5 Re: gtp start sputter
    Wilkes Barre, PA
    It only does it sometimes.. other times it will start how it normally should. Usually if it does that i just give it a quick rev and it will idle normally..
  6. #6 Re: gtp start sputter
    HUDSON
    If you can put a fuel pressure gauge on it, you will be able to watch the pressure, before start, and after start, and after you shut it off. This will tell you is you have a bad pressure regulator, leaking injector, clogger fuel filter, and stuff..
    Dean
  7. #7 Re: gtp start sputter
    Wilkes Barre, PA
    Okay i just scanned the codes the pcm was throwing and i was getting the p0171 system too lean bank 1.. So i might have a vacuum leak.. could that be why my car starts like this? Also, i re-oiled my k&n filter not too long ago could that have dirtied the MAF sensor?
  8. #8 Re: gtp start sputter
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by zildjian102 View Post
    Your boost gauge was reading low vacuum at idle. Id suspect a vac leak. but if its intermit then it might be a fueling issue. Se what FP you have at idle
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: gtp start sputter
    Wilkes Barre, PA
    What should the vacuum be around on the boost gauge? And is it free to get the fuel pressure checked?
  10. #10 Re: gtp start sputter
    Wilkes Barre, PA
    I found out that the throttle body gasket was half gone! replaced that and the car runs beautifully now!
  11. #11 Re: gtp start sputter
    Charles City, IA
    So it was a vac leak.
  12. #12 Re: gtp start sputter
    Wilkes Barre, PA
    yea it was makin the car run really lean
  1. Car starts to sputter between 2k and 2.5k rpms
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 11:24 AM
  2. tick sputter and p0302
    By musiknjoyr in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-26-2010, 01:22 PM
  3. bad sputter new guy
    By DIRTYDEVIL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2010, 04:15 PM
  4. where to start
    By Jakegday in forum PCM Tuning
    Last Post: 08-04-2009, 12:51 AM
  5. no start
    By betsgtp in forum General Tech Discussion
    Last Post: 06-05-2009, 12:19 AM
