Thread: Key won't turn over
Results 1 to 14 of 14
  1. #1 Key won't turn over
    Lower Keys, FL
    I just got a new key cut by the dealer and it still won't turn the ignition... any suggestions or anything at all ....helllllllllp
  2. #2 Re: Key won't turn over
    What details? there still are none. Start the story over.
  3. #3 Re: Key won't turn over
    Lower Keys, FL
    The wife lost the keys while is was deployed overseas. Got the dealer to cut a new one for me (PK3). It won't turn over even now. I've had problems in the past with the selinoid and the magnetic release, but I've pulled the plug out of the bottom cover under the steering wheel in order to get the key to release. No problems out of that since. It's been sitting for 4 or 5 months and now that I have a new key I can't get it to turn at all. When the key's inserted it makes the the connections lights and dings and what not.
  4. #4 Re: Key won't turn over
    Quote Originally Posted by MattyJ View Post
    sitting for 4 or 5 months,,dead battery charge it up or test it.
  5. #5 Re: Key won't turn over
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    That was my original thought as well, but I was understanding that he can't turn the key, not the engine over...
    MattyJ, Which is it?
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  6. #6 Re: Key won't turn over
    does the security light come on?
    As in, was the key programed by the dealership as well?
  7. #7 Re: Key won't turn over
    Lower Keys, FL
    The light blinks but that's it. The key was coded by the dealership. As for the programming, no. They said the car had to be there for them to do it. No key meant a tow truck. That I can't afford at this junction. Programming it myself seemed to be the only other alternative
  8. #8 Re: Key won't turn over
    Tyler, TX
    programming? really? ...it's just a piece of metal. I got a spare key cut for $2 at the hardware store and it worked just fine. What am I missing here. My key is a PK3 as well...
    However, the key was a tad bit off in the cutter and I had to pull the key out just a hair in order for the lock to line up right. Try that...
  9. #9 Re: Key won't turn over
    Lower Keys, FL
    The Key won't turn in the ignition. The battery's charged.
  10. #10 Re: Key won't turn over
    if u got lights and the dash lights up it may be the starter,,try giving it a few nice hits with a hammer, or take it out and have it tested, no car likes to sit for months. it may have seized up. or the solenoid took a dump. just a shot in the dark, good luck
  11. #11 Re: Key won't turn over
    Lower Keys, FL
    Thanks, but it has to be something in the switch. I don't get lights on the dash just the doors with the door open ding stopping when the key is inserted. i can't even get it to turn in the switch to see what other problems there may be. I'm about to take a hammer to the whole thing
  12. #12 Re: Key won't turn over
    i feel ya lol. theres plenty of write ups on the ignition switch replacement, from what I've read/ remember they are pretty cheep to buy a new one, i haven't have the pleasure of doing one yet, just jinxed myself i know it.
  13. #13 Re: Key won't turn over
    GT Level Member Deviq's Avatar
    SE WI
    I would take it back to the dealer.. sounds like they cut it wrong.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  14. #14 Re: Key won't turn over
    Feb 2010
    South Dakota
    nope try taking the lock cylinder out of the ignition. had it happen to two cars on me. i tested coil on the one and it was open don`t know about the other. its just below the key inside the steering colum. it just pushes or pulls on a locking pin for the key. pull the cover off the ignition its got a white plastic clip that holds the steel body in. Just BS ya dont need it.
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. Please help !!! Car won't turn !!!
    By PontiacGrandPrixGT in forum General Tech Discussion
    Last Post: 08-25-2010, 10:16 PM
  3. Cant turn off car right away...
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 03-07-2010, 11:20 PM
  4. Cant turn key off sometimes?
    By PCweber in forum General Tech Discussion
    Last Post: 08-30-2009, 01:28 PM
  5. Key won't turn
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2009, 05:17 PM
