Thread: catalytic converter
Results 1 to 11 of 11
  1. #1 catalytic converter
    Jan 2009
    Michigan
    I got the beginnings of an exhaust leak at the catalytic converter and was thinking of just getting rid of it and welding in some pipe. Does anyone know if this will throw the check engine light. Any negative effects and how much louder will it be?
  2. #2 Re: catalytic converter
    Hagerstown,Md
    Yes it will toss a check engine light. No it will not change the tone
  3. #3 Re: catalytic converter
    GTP Level Member
    Nov 2008
    MA
    replacing the stock (restrictive) cat with straight pipe most def. change the exhaust note..just not crazy dif.
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  4. #4 Re: catalytic converter
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    u can get a plug in sensor to fake a code from the rear o2 sensor or get it tuned to avoud the light coming on and do the resonator while your at it..itll get raspy though
  5. #5 Re: catalytic converter
    Jan 2009
    Michigan
    I got under it yesterday and the leak is actually coming from what looks to be some type of resonator. It is a long piece that is long and round with a seam along the side. Is this the resonator and if it is removed with it toss the check engine?
  6. #6 Re: catalytic converter
    Feb 2010
    somewhere cold
    remove it and no it wont turn the lignt on
  7. #7 Re: catalytic converter
    Charles City, IA
    I would replace it with a glass pack muffler.
    SMGPFC Two Nipple General
  8. #8 Re: catalytic converter
    Jan 2009
    Michigan
    Will that change the tone of the exhaust?
  9. #9 Re: catalytic converter
    MO
    Removing the resonator makes it sound like poo. A glasspack will fix that.
    <brandonl2000> LMAO D!!
  10. #10 Re: catalytic converter
    Don't ever delete the resonator...it makes the exhaust note drone on the highway and gives your exhaust rasp...which you dont want. Deleting the cat and keeping the resonator sounds great...especially if you get rid of the stock resonator with a big glasspack...probably about 26+ inches.
  11. #11 Re: catalytic converter
    Jan 2009
    Michigan
    Where is the best place to get a long and cheap glasspack?
  1. L36 Catalytic Converter Warranty
    By Scimmia in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 01:30 PM
  2. I need to no were i can get a catalytic converter.
    By krazyog1 in forum 04+ Specifics
    Last Post: 10-06-2009, 03:53 PM
  3. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
