The car is a 97 gtp. The fuel pump will not turn on with the key turned. I tried doing a fuel pump re-wire and see if that would fix it. the fuel pump and regulator have been replaced, along with a fuel pump back in april. I think just the pump was not replaced and not the entire assembly. I seem to be getting voltage to the pigtail that connects into the fuel pump (2.5 volts out of the prong with the black wire, the battery was dying on the car)
I was going to do the "high speed" mod, but on this 97 there isn't a relay for it. I also tested the fuel pump relay, which seems to be working since, i swapped one in from my other car. I never hear the fuel pump prime but if the car sits all night, i can start the car and drive it without issue at all (even though i never hear the pump turn on) then when i turn it off and try to re-start the car it cranks but no start
i was thinking these, im trying to rule out the following...
cam position sensor
crank position sensor
fuel pump assembly unit
bad pcm
does anyone know if the cam and/or crank position sensor have to do anything with tripping current to the fuel pump?
