hello all. i just want to see if im understanding this correctly.... to remove the subframe, all i need to do is support the engine from above, remove the control arms, remove the 2 bolts on the bottom of the motor mount and 2 bolts on bottom of tranny mount, and then the 4 main bolts holding it to the body?
also, i understand it may not be necessary to remove the control arms. i simply have that in there for weight purposes...
