My PS is leaking but I can't find from where, have not looked real hard yet...
Anyways after the car has been running and I pull off the PS cap, it like pops off from air pressure. I have bled the system a few times..
Anyways is it suppose to be like air tight? I was contemplating putting a small hole somewhere around the cap seal just to let air pressure escape.
Given the rate I am losing it (slowly) I am guessing it is in the low pressure end. So, do I have a good idea as a "rig fix"? Is there something else causing the air pressure in the reservoir?
BTW it stays full of fluid, between the marks.
