Ok so i need some L67 heads for my top swap, but if i find a set of heads thats been torn down, what exactly can i take off my L36 heads and put onto the L67 heads?
Lifters, rods, rockers, bolts, springs, retainers, and locks are all the same.
You will want aftermarket bolts though. They are TTY.
and if you EVER plan on taking the heads off again.... get head studs.
Get reusable rocker bolts for sure, they're a dollar more...
Alright thanks for the info guys, makes my head search a little easier. And ill definitely spring for the head studs and reusable rocker bolts.
FWIW...if you have a ACE hardware close to you...you can get the re-useable rocker bolts there for like 70 cents a pop LOL Same exact bolt as the comp ones...I've been running them since I had rockers 3 years ago. Just a little dab of loctite and bam. Re-usable rocker bolts for under $9.
shiiiz lol thanks. Oh and what about valve covers? can i use my old ones too?
Bump
you HAVE to lol
Lol ok well i didnt want to buy new ones if i didnt have to.
true.
and by that i mean you have to use your own rocker covers.
