Thread: Key sticks in ignition, is there a Diagnostic Chart?
Results 1 to 7 of 7
  1. #1 Key sticks in ignition, is there a Diagnostic Chart?
    SE Level Member techweenie's Avatar
    Nov 2009
    Grand Blanc, MI
    My key has randomly been getting stuck in the ignition, and rather than cheat my way around the problem I want to fix it properly. My car is in extremely good condition and I want to be able to resell it with zero problems. I think I read somewhere on here there's a flowchart to figure out what causes the key to get stuck, so does anyone have it? I'm sure its in the factory service books which I'd rather not buy if I can avoid it. It's an 02 GTP.
  2. #2 Re: Key sticks in ignition, is there a Diagnostic Chart?
    Minnesota
    turn the key to on, shift into neutral then back to park and make sure its into park good. then turn the key to off, it should come out. The neutral safety switch could be bad
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  3. #3 Re: Key sticks in ignition, is there a Diagnostic Chart?
    Nov 2009
    Grand Blanc, MI
    My ignition switch was bad and I replaced that today. From what I've read, that should fix this problem as well.
  4. #4 Re: Key sticks in ignition, is there a Diagnostic Chart?
    MO
    stuck in the ignition? turn your wheel slightly to unstick it
    <brandonl2000> LMAO D!!
  5. #5 Re: Key sticks in ignition, is there a Diagnostic Chart?
    Just randomly sticks in there and you have to put a screwdriver or something in the underside of the steering wheel cover to release the key? If so...its the white lock cylinder under the dash...pull the tilt level off and then take off the bottom cover...it is a small white cylinder...just yank it out...problem solved.
  6. #6 Re: Key sticks in ignition, is there a Diagnostic Chart?
    Charles City, IA
    What see said, you will never know its gone.
    SMGPFC Two Nipple General
  7. #7 Re: Key sticks in ignition, is there a Diagnostic Chart?
    Nov 2009
    Grand Blanc, MI
    If it happens again I will remove that cylinder. It hasn't happened since replacing the ignition switch and its rare when it does happen. Jiggling the steering wheel never releases it.
  1. vac leak? cat diagnostic?
    By vailskier3 in forum PCM Tuning
    Last Post: 05-09-2010, 10:17 PM
  2. 2001 GT tune chart
    By racecardude310 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 10:19 PM
  3. no 91 3.1's on that chart???
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-31-2009, 08:44 PM
  4. I need diagnostic help!! PO502 and PO503 PLEASE
    By GTPOWER in forum General Tech Discussion
    Last Post: 08-01-2008, 07:07 PM
  5. MAF problem - need diagnostic help...
    By Boatman in forum General Tech Discussion
    Last Post: 05-25-2008, 10:21 PM
