Thread: Removing the door panels
Results 1 to 8 of 8
  1. #1 Removing the door panels
    So I have never taken off the door panels of my 4 door,
    but I need to take my mirrors off, so they need to come off.
    Can someone please post some pics of the procedure, and what
    clips are infamous for breaking. THanks!
    Wiz, Wideband O2, 78mm T/B, P&P SC, SSIC, P&P LIM, 3", 1.8CCRR's, CC push rods, Custom covers, SLP headers, Meziere Water pump 3" Magnaflow, Race Tranny, 20" Concept One Wheels, Coilovers, BMR F&R suspension, Custom Body and Paint, Custom interior and sound.
  2. #2 Re: Removing the door panels
    Saraland Alabama
    2 bolts near door pull, and a bunch of plastic clips that break half the time (get a box of new ones you'll need them) they come off pretty easy
  3. #3 Re: Removing the door panels
    Oklahoma
    archemedes, where is the best place to get those clips?
  4. #4 Re: Removing the door panels
    Saraland Alabama
    most parts stores have them in the help section under $5 for a box I think (I buy bulk from one of my distributors no clue what I pay anymore)
  5. #5 Re: Removing the door panels
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    In AutoZone at the nuts and bolts section, orange boxes, they're white clips for GM vehicles, $2.99 a pack.
    As far as the bolts, they're torx heads and if you look under the inside door pull you'll see two cosmetic plugs. Remove those and you'll have access to the bolts, they're installed at an upwards angle. After that, just start pulling. Be mindful of the plugs for the window switches and courtesy light (you can remove it before hand, your choice) and door handle.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  6. #6 Re: Removing the door panels
    thanks guys!
    I will be trying to get them off this week so I can get the damn mirrors off.
  7. #7 Re: Removing the door panels
    SE Level Member Sinister Drag Designs's Avatar
    Why are you removing the mirrors?
  8. #8 Re: Removing the door panels
    Louisville, KY
    Can't you just pull the top plate cover off a bit and then use a combination wrench to get those out without removing the whole door panel? Then disconnect the power wires?
    My Cardomain
  1. Removing alternator housing
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 06:14 PM
  2. Finished Kick Panels.
    By snow99dohc in forum Audio, Security & Visual Electronics
    Last Post: 12-24-2009, 10:55 PM
  3. Removing motor with no heads on it ....
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2008, 09:23 PM
  4. So I found an easy how to on carbon fiber panels
    By s1795so2 in forum Visual/Body Modifications
    Last Post: 01-22-2008, 05:13 PM
