my lights in my gear inducator consule ( or whatever you would call it) stopped working how can i fix this its a 07 na
You may just have a burnt out bulb. Check the fuses in you fuse box first. Then if it isn't a blown fuse & you think you can do it; dismantle your center console and replace the bulb.
i've checked all the fuses so yeah im gonna have to replace the lights, is this tricky or any tips
just be gentle on all the plastic bits when you pop the console out. Make sure you drink holder is out and put your gear shift in 1.
In order to change this bulb u need to take the two bolts out of the rear of the counsle one on each side then one on each side towards the front. You will also need to take the shift knob off, it is a small phillps on the front of the knob. When u go to pull it off it is hard because they used a clip towards the back. aslo wires to watch out for. The bulb is a 194 located under the shift selector. any questions feel free to ask
