does anyone know where i can find diagrams for the torque sequence for oil pan gasket, exhaust manifold gaskets, and supercharger gaskets for a 1999 gtp. also can i block off the egr without setting a code. thanks in advance.
if ur lookin for torque specs on oil pan and manifolds then look in how to section should be in there.. You will set off a code if you block the egr off , you need to find someone with a tuner so they can make the code stay away..
