Thread: winshield washer hose
Results 1 to 5 of 5
  1. #1 winshield washer hose
    Lincoln, ma
    Hey I have an 07 gp base the car came with the flaw (and yes the dealership will fix it for free, but nothings really free) but the sprayer for the washer fluid on the drivers side doesnt exactly spray and i looked at the wiper not the blade the arm with the sprayers and theres two i took all the hoses off put new ones on and they didnt fit as snug as it seemed and they didnt work but the oem hoses none of them were blocked. I did a homemade blow test haha took them all and blew into them they were all fine and when i use the windshield washers water dribbles out of the bottom sprayer but not the top and so ive concluded that the actual sprayers and clogged and when looking at them it looks as if theres something stuck inside. my actualy question is where can i find replacement oem parts i cant even seem to find the original hose and i love my dealership longtime friends of the family (my grandparents babysat the owners and workers, my parents went to highschool with them etc.) but i dont trust or like theyre mechanics simply cuz i hate paying money for them to type BS repairs they didnt even do. if anyone knows how i could un clog the system or how i could replace it any info would be much appreciated. my uncle owns an auto shop and he even had trouble locating the stuff so basically my options are junkyard and thats about it
  2. #2 Re: winshield washer hose
    Charles City, IA
    You have to get the whole wiper arm. GM parts direct has them both for about $40
    SMGPFC Two Nipple General
  3. #3 Re: winshield washer hose
    Lincoln, ma
    wow that sucks but thanks for the response appreciate it
  4. #4 Re: winshield washer hose
    Destroys cars izup69's Avatar
    Iowa
    When u go to the dealership tell them if they do anything else to the car your not paying for it and get them to type it up (basically a informal contract) It will hold up in court if they try to charge you for anything else
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  5. #5 Re: winshield washer hose
    Feb 2010
    mn
    I work at a dealer and I have the same problem with my 06 gp. I ended up eliminating the bottom nozzle and just running the hose right up to the top one. I think the real problem in the whole system is the poor little pump cant flow enough fluid to keep pressure in the lines with 4 nozzles. in the long term my car will probably end up with 2 pumps one for each side and put the lower nozzles back in. oh yea and I looked too and you can only get the complete arm not individual parts.
    06 gt sc all stock. 36k on it.
  1. rubber seal around winshield
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 07-23-2010, 07:04 PM
  2. washer pump????
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-12-2010, 11:24 PM
  3. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  4. winshield wiper help
    By RedLedbetter in forum General Tech Discussion
    Last Post: 04-07-2009, 06:48 PM
  5. Washer not working!
    By Dangerous313KidInAPrix in forum General Tech Discussion
    Last Post: 03-09-2009, 08:36 AM
