Thread: How could I tell if there has been engine damage?
Results 1 to 11 of 11
  1. #1 How could I tell if there has been engine damage?
    MA
    if this is the wrong section feel free to move it.
    Well guys after searching for quite a while now i think ive found a car that i want. it seems perfect. its an 02 thats got a basic 3.4 setup and looks really clean. my only concern is the guy has a zzp pcm in it. now i know zzps tunes are notorious for running lean, the guy says it is a bit lean and it throws a code every once in a while.
    My question is.. is there a sure fire way to test if the engine is damaged, without pulling it all apart? im mostly woried about a chipped piston, but im sure there are other things that can result from running too lean.
    im going to look at it tommorow, all input will be greatly appreciated. TIA
    SMGPFC Member #9
  2. #2 Re: How could I tell if there has been engine damage?
    Jan 1970
    Maquoketa, Iowa
    Like a compression test?
  3. #3 Re: How could I tell if there has been engine damage?
    Nov 2009
    Grand haven
    get a bore scope or borrow one.
  4. #4 Re: How could I tell if there has been engine damage?
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by shawngtp View Post
    ^ that... then pull plugs and take a look... those tools are awesome.. used one to back up my cracked flex plate theory on my car.
    02 GTP with mods 05 GP for DD
  5. #5 Re: How could I tell if there has been engine damage?
    Charles City, IA
    Yup do a compression test or rent a bore scope. More then likely the car is fine.
    SMGPFC Two Nipple General
  6. #6 Re: How could I tell if there has been engine damage?
    compression tests fail in comparison to a leak down test.
  7. #7 Re: How could I tell if there has been engine damage?
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Simple.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  8. #8 Re: How could I tell if there has been engine damage?
    MA
    thanks guys. i was thinking compression test, wasnt sure though.
    so i just came back from checking the car out, it looks and runs beautiful. the only problem is that its blowing a few codes.
    the guy said they popped up after he put in his speed daddys. he checked on his aeroforce and said its throwing a high voltage and a low voltage code, 171 and 131. as well as a 135. what could cause these? and has anyone thrown a code for running too lean on a zzp canned tune?
    and has anyone else had codes show up after putting in their speed daddy headers. Mine did and his did. i just dont want to end up in the same boat as i was in with my old gtp
    SMGPFC Member #9
  9. #9 Re: How could I tell if there has been engine damage?
    Hagerstown,Md
    Had a p1133 code on mine after headers. I just deleted deleted the code in the pcm. If its tossing a lean code it more then likely has a vacuum leak
  10. #10 Re: How could I tell if there has been engine damage?
    MA
    thanks man. it didnt sound like it had a vac leak.
    SMGPFC Member #9
  11. #11 Re: How could I tell if there has been engine damage?
    MA
    bump?????????
    really want this car< really dont want more bull**** trouble
    SMGPFC Member #9
  1. jumpstart PCM damage?
    By Juanmiguel in forum General Tech Discussion
    Last Post: 07-30-2010, 06:43 PM
  2. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  3. Flexplate damage?
    By krippled in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2009, 11:58 AM
  4. Whats the Damage?
    By MARKS99 in forum General Tech Discussion
    Last Post: 03-26-2009, 05:25 PM
