Thread: Gas guage too active
Results 1 to 8 of 8
  1. #1 Gas guage too active
    Seattle
    MY 1997 has the problem that anything under a quarter tank (only a needle's width away from the 1/4 mark) the "low gas warning system" kicks in. I see on the "differences list" on the 1998 section is says "fixed the problem with the fuel level sending unit" Is this the same problem and can I just put in a 1998 or later sending unit to solve this?
  2. #2 Re: Gas guage too active
    SE Level Member Blackbird87's Avatar
    Dec 2010
    Chicago
    Filling the tank would fix the issue and maybe make your fuel pump last longer
  3. #3 Re: Gas guage too active
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    these cars seem to scream bloody murder for gas when the tank is 2/3 empty.not just the 97. I just fill it up when I've used about 13.5 gallons.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  4. #4 Re: Gas guage too active
    GTX Level Member cerick08GP's Avatar
    I’d wait until the light comes on again, and then go fill it up right way. Then compare the gallons filled with the usable gas tank volume from your owner’s manual. This is just a hunch, but I’d bet the light is coming on when it is supposed to. I say this because my 03GP gas gauge was less than linear.
    Oh, and 3x on keeping the gas tank on the high side. Keeping the tank fuller will protect the fuel pump from over heating, and it will minimize fuel tank rusting.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Gas guage too active
    Michigain
    I'd put money on it being the sending unit which is also part of the fuel pump. I use to work for g.m and this is a pretty common issue with all there car's on the road today. Wait for the fuel pump to fail or if it bug's you that much, just replace it and be done with it.
    1998 Caged \ Drag GTP = Demoded & Sold
    1999 Caged \ Stattam Turboed GTP hunting for Low 10's
    2008 TrailBlazer SS AWD LS2 400 H.P
  6. #6 Re: Gas guage too active
    Bonnevilles had a similar issue in 97. GM did a change and to my knowledge that made the sender have a larger resistance value swing. Say 97 is 0-90 ohms and 98 would be something like 0-255 ohms. This means you probably can't use the sender. Checking the info in the FSM would tell you for sure though.
    Also .. afterthought here.. 97 didn't have the pressure sensor on the pump did it?
  7. #7 Re: Gas guage too active
    Michigain
    Good Call, that I did not think about.
  8. #8 Re: Gas guage too active
    Seattle
    Thank you for the above points. How would I know if mine has the pressure sensor on it?
  1. Most active user on the forums
    By Rocket468 in forum Site/Club News
    Last Post: 02-01-2014, 01:16 PM
  2. Battery Saver Active
    By garreTT in forum General Tech Discussion
    Last Post: 12-08-2010, 09:22 PM
  3. Anyone active with a bagged gp?
    By GAFF in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2010, 08:08 PM
  4. Need a favor, some one still active on CGP?
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 04-11-2008, 03:24 PM
