So i'm going to drop my trans pan tomorrow, change the filter and fill it back up. Is it good to fill it with dex VI even though the converter will still be full of dexIII? And how much fluid should i buy? i was thinking 8 quarts should do it
get the newest dexron and yes 8 should do it, are you getting that kit (filter and gasket), i think the rubber gaskets are better which is the one in a kit a bought
If the gasket you take off is rubber with metal inside, that's the factory (expected lifetime) gasket and you should resuse it. Read the instructions that come with the service kit about filter neck being snug and not replacing the collar if it's snug.
The factory gasket is a pricey gasket and it's the best you can get. Those rubber ones work, but they don't work like a factory gasket.
