Thread: Head Resurfacing question
Results 1 to 8 of 8
  1. #1 Head Resurfacing question
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    I have a question if anybody can help me but not about my prix. I am working on an LS1. Changing head gaskets to be specific. The owner sent the heads to get rebuilt. I'm not sure how smooth the surface should be but its a lot rougher than the block deck. it looks as if they used a large sander to do the resurfacing cause i can see and feel all the little scratches that a belt sander would leave. is this normal or should it be just like the block. its smooth but not when i run my nail perpendicular to the lines. can anybody help?
  2. #2 Re: Head Resurfacing question
    Charles City, IA
    Should be fine, some times they leave them a little rough to help them seal.
    SMGPFC Two Nipple General
  3. #3 Re: Head Resurfacing question
    Jul 2010
    TX
    How many miles you think I could get out of this engine before it starts to leak coolant or overheat?
  4. #4 Re: Head Resurfacing question
    Jul 2010
    TX
    Look guys, I'm a mechanic from South Texas. I have fixed a whole lot of vehicles. even fords. ( yes I am ashamed but it payed bills) lol. I have 4 vehicles to fix right now and that's not including mine which needs a swap. I have the engine ready but can't start until customers have theirs. I'm frustrated cause I have no Co workers. A friend told me to use that copper spray that is used on head shims. does anybody have any experience with these type of machine shops and what they used to fix this. I just wanna make sure the car last at least 50,000 miles form this piece of s**t resurfacing.
  5. #5 Re: Head Resurfacing question
    Jul 2010
    Manitoba
    minor grooves should not be a problem as long as the heads are not warped the head gasket will fill imperfections, but if you feel they are that bad you have a couple options 1- use a straight line air sander with a fine grit, work it evenly over the head and it will stay true and it does not take much to clean it up 2- you can use a die grinder with a scotch bright surfacing disk (medium grit) keep in mind that this method requires a fair amount of finesse as you cand gouge a head if you hold it in one spot.
    i have used both methods when replacing head gaskets/seals on diesel engines and have not had a leak yet and some engines are approaching 400k since they were done, on a side note i'm not sure if you are dealing with steel or aluminum heads but method #2 should not be done on aluminum heads unless you use great care
  6. #6 Re: Head Resurfacing question
    gaskets all go on dry unless youre using the metal layered ones (and those suck anyway).
  7. #7 Re: Head Resurfacing question
    Apr 2009
    stockton ca
    basically a head surfacer is a big belt sander so texture is fine should last a long while as long as everything is torqued correctly
  8. #8 Re: Head Resurfacing question
    Jul 2010
    TX
    Thanks everyone
  1. head question
    By selliott in forum General Tech Discussion
    Last Post: 06-09-2009, 02:18 PM
  2. Head Gasket Question
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 11:31 PM
  3. speaker and head unit question
    By biggmman in forum Audio, Security & Visual Electronics
    Last Post: 10-06-2008, 09:18 PM
  4. Head Unit Question
    By Minno in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2008, 01:52 AM
  5. another pioneer head unit question
    By nemesis in forum Audio, Security & Visual Electronics
    Last Post: 03-22-2008, 07:06 PM
