Thread: A car issue
Results 1 to 6 of 6
  1. #1 A car issue
    SE Level Member NashGT02's Avatar
    Davenport, IA
    Ok so lately the car has been acting funny. For example today I started my car and was just about to leave and turned on my ac and then went to mess with DIC to see what my range was and I heard a click and my ac shut off and DIC shut off. Didnt pay attention to what else turned off so I was wtf for a second and turned off the ac and it all came back on and turned the ac back on and all was well for the trip to and from work. it almost sounds like a relay clicking or something. Anyone have any thoughts on what this could be? My ignition lock cylinder has been messing with me lately but I dont think this has anything to do with it. please someone help me out before this turns into a major problem down the road.
  2. #2 Re: A car issue
    Davenport, IA
    no one has an idea of what it could be?
  3. #3 Re: A car issue
    Outer Space
    if your dic is going on and off, and your ac is acting funny... like some speeds don't work all the time... its sounds to me like the symptoms of a bad ignition switch. Search for some ignition switch threads and see if that is what's happening.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: A car issue
    Davenport, IA
    I had figured my ignition switch is on its way out but I didnt think it would cause my DIC and AC to fail completly. The car ran fine while they shut off. Its only done it once so far and it shut off completly but when it came back on it all worked just fine. If its the ignition switch im ok with that I know what that takes to replace I was just afriad it was more then that. moneys a little tight right now so Im crossing my fingers it holds together for awhile longer
  5. #5 Re: A car issue
    Outer Space
    Quote Originally Posted by NashGT02 View Post
    Check my thread, when it happened to me.
    http://www.grandprixforums.net/troub...sue-16582.html
  6. #6 Re: A car issue
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    it's ignition switch. the ignition lock cylinder problem will automagically be fixed too.
  1. KR issue, need help
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2010, 12:40 AM
  2. MAF Issue
    By prostallion347 in forum General Tech Discussion
    Last Post: 03-30-2010, 11:36 AM
  3. RPM Issue
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-19-2009, 01:32 PM
  4. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  5. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
