Thread: Odd electric problem?
Results 1 to 7 of 7
  1. #1 Odd electric problem?
    Minnesota
    About a month ago I installed some new ballasts for my HIDs (Keep in mind I have the relay and wiring straight to the battery). When I turned them on I kept hearing a sound weird sound coming from the front of the car (Might have been the ballasts or might have been something else). Needless to say I decided not to use those ballasts. From then on I started to have two problems.
    1. My A/C and lower control buttons only light up when I have the parking or headlights on NOT when I just have the DRLs on. I can't see if I have the A/C, rear defrost ect. buttons on while the DRLs are on. The buttons wont light up although they will when I have the headlights or parking lights on.
    2. My airbag light keeps coming on and off randomly while I driving. I read the code and its B0041 (LF side deployment loop open.)
    --I tried reinstalling my original PCM with nothing changed. Could this be a bad DRL relay causing a short or would it more than likely be the BCM is bad?
  2. #2 Re: Odd electric problem?
    Minnesota
    Bumper
  3. #3 Re: Odd electric problem?
    Wichita
    Maybe when you installed the ballasts a fuse or two blew. Check out your fuse boxes.
  4. #4 Re: Odd electric problem?
    Minnesota
    Checked all the fuses and nothing has blown. Plus the A/C controls light up but not when the DRLs are on? I might try and replace the DRL relay but am open to suggestions. I don't think the DRL relay could be setting the Airbag light though.
  5. #5 Re: Odd electric problem?
    Wichita
    Hrm, only other thing I can think of is to check for a bad ground.
  6. #6 Re: Odd electric problem?
    Minnesota
    Well the two issues were coincidence because I fixed the airbag problem. It was the connector under the seat. The wires going into the yellow connector were loose I wiggled it around to see if it was the problem and sure enough it was. Now I am still trying to figure out the climate controls. I bought some relays, installed them and nothing changed. The only thing I can think to do next is replace the climate controls and see if that works. I checked the grounds and even checked the grounding strap that is under the airbox (now a K&N CAI) and they look good.
  7. #7 Re: Odd electric problem?
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    pull your fuse box and make sure nothing got hot on the back of it. sounds like you have some wires touching together behind the fusebox.
    <MiZzBeCcA>its not rape if you yell suprise
  1. electric pump yes or no?
    By l67swap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2013, 10:37 PM
  2. 02 SE Major Electric Problem
    By rs2sensen in forum General Tech Discussion
    Last Post: 02-28-2010, 04:40 PM
  3. Electric problem
    By Gaetusss in forum Audio, Security & Visual Electronics
    Last Post: 05-04-2009, 06:58 PM
  4. electric cut-out on the car
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:06 AM
