Thread: Please Help Quick!
Results 1 to 4 of 4
  1. #1 Please Help Quick!
    May 2008
    I'm currently working on a friends 01 gtp. He's got a clunk noise coming from the driver side front wheel area. The ONLY time it clunks is when you hit some bumps, never turning or anything. The front struts are pretty new, and the strut mounts, (just looking at them) dont look bad at all. The control arms, sway bar, cv joint, all look good, so I just dont know what to look for. Please help guys!
  2. #2 Re: Please Help Quick!
    Saraland Alabama
    sway bar link is pretty common, and cheap (hard to check)
  3. #3 Re: Please Help Quick!
    I live here. UR LOSN's Avatar
    Rockford, IL
    sway bar itself, or sway bar end links.
    the front sway bars like to snap in half.....old age, metal fatigue....
  4. #4 Re: Please Help Quick!
    PA
    I would say sway bar as well. Or control arm bushings as they can pull away from the metal and cause a clunk.
    Also, if new struts were installed, I would have recommended to change the strut mounts as well. The struts will far outlast the mounts and should be changed when installing new struts.
    And if they were changed, look for loose bolts. Particularly under the hood where the strut bolts to the body, and the center strut nut is. Check those to make sure they are all tight. And double check the sub frame bolts, that they have not come loose.
    2001 GSE
  1. quick questions
    By mexico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2008, 04:13 PM
  2. Quick Q: Torque Converter
    By TommyGloves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2008, 07:06 AM
  3. Help quick
    By evlprx in forum General Tech Discussion
    Last Post: 02-24-2008, 07:16 PM
