Thread: AC Condensor
Results 1 to 2 of 2
  1. #1 AC Condensor
    ny
    What is the AC condensor type in a 1997 GTP? Is it parrallel, serpentine or round-tube?
    I have a failed AC compressor, and just about to replace it with a new one (along with o-tube and accumulator etc...).
    I think the factory condensor is the parralel type. I've read that parrallel type condensors are NOT capable of being flushed.
    Everything I hear says it's absolutely imperative to flush the AC lines, evaporator, and condensor.
    If all the above logic is true, then all failed compressors automatically require a new condensor?
    Also, how many ounces of PAG oil do I need for the 3.8 vin 1?
    What are the optimal 1997 GTP gage pressures for hi low side (engine off, & engine on-ac at max)
    The average for most ac systems is 125 (engine off) & 25 psi low 250 psi high (engine on/ac max).
    Thank you!
    -Chris
  2. #2 Re: AC Condensor
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Not sure i did flush mine but i am no a pro.
    My EX wifes other car is a broom.
