Thread: And ... it begins.
Results 1 to 20 of 24
  1. #1 And ... it begins.
    SE Level Member jdwyat's Avatar
    Jul 2010
    Dothan, AL
    I've looked at a mechanic, and to start off.. .I have him pricing out the below list.
    · New Spark Plugs (Platinum?) Mechanic recommends them.. only because "they last longer".
    · New Spark Plug Wires (MSD Ignition / red) yes.. cause I want the color. LoL
    · Fuel Filter Change
    · New Thermostat (upgrade to a 180*/160* Thermostat) I just recently replaced the original thermostat.. I neglected to replace it with a 180. The coolant system was flushed then. Now, just going to replace the thermostat.. again.
    · Lower Intake Manifold Gaskets/Coolant Elbows (2)
    (metal gasket?) I asked the mechanic if he could find a metal gasket to replace with. He's searching....
    · Replace headers w/ Speed Daddy or equivalent & Replace Cat w/ Magnaflow. The existing Cat needs replacing, and might as well jump to something that has a tad more rumble... I can't for the life of me find the Speed Daddy headers you all so love...
    · Transmission Pan Drop/New GM Transmission Filter (Replace 3-4 quarts with Dexron VI, not Dexron IV)
    · Supercharger Oil Change (Replace with 2 New Bottles of GM Supercharger Oil)
    · K&N Air Intake/ Jet MAFS replace. I'm seeing what his prices are on the two parts. I mentioned I'd like to simply tie a conical filter directly to the MAFS. We might do that... I just want to see where it's positioned after installing the MAFS.
    · Check Motor mounts. This goes along with looking under and over the vehicle for other potential issues. (already did new brakes, thermostat and belts before hitting this forum)
    Suggestions, questions, helpful advice. All feedback is welcome.
  2. #2 Re: And ... it begins.
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    The Supercharger Oil is a SUPER Easy thing that any one can do on thier own. Took me 20 minutes and only cost me in the realm of $20. If i can manage something Anyone can!
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: And ... it begins.
    you could seriously do the majority of that stuff in a day, and the rest of it the day after. take your time, learn something about your car, and be able to fix it the next time its broke.
  4. #4 Re: And ... it begins.
    And platinum plugs suck...and the JET MAF does absolutely nothing. GO read my Safely Modding thread if your going to start throwing performance parts at it.
  5. #5 Re: And ... it begins.
    Pennsylvania
    Copper plugs are great only if you like to change your spark plugs every 15k miles. Otherwise, get something more expensive.
  6. #6 Re: And ... it begins.
    GT Level Member AmericanRiceEater's Avatar
    New York
    Do you have the GTP ?
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  7. #7 Re: And ... it begins.
    Jul 2010
    Dothan, AL
    I did.... that's where that list came from.
    and yes siree.. GTP
    I'm not looking forward to draining the supercharger. I researched it a bit, and thus far the biggest concern I see is to ensure it's absolutely cold before I pull the drain plug.
    Most everything on that list will be worked by yours truly. I need the mechanic to help me with doing the intake manifold gasket/headers/cat. He has the necessary tools... He's also going to try to get me a better price on parts... I found the Magnaflow Cat for almost 300 .. he can get it for 150. The difference more than pays for his labor. I will be hands on though.. gotta learn somehow.
    And since this is also my daily driver, until I can secure another vehicle.. I'll need to have someone around that knows what the hell they're doing.
    Platinum plugs don't appear to be as outrageous a cost as I originally expected...
    I can see the benefit of paying a little extra and not having to change them out as often.
    I figure if they last 50% longer than copper.. than they've justified the difference in cost.
  8. #8 Re: And ... it begins.
    Pennsylvania
    Quote Originally Posted by jdwyat View Post
    ZZ Performance
  9. #9 Re: And ... it begins.
    You are gunna need alot more that 3-4 quarts of tranny fluid on a pan drop. Get at least 7 bottles.
  10. #10 Re: And ... it begins.
    Jul 2010
    Dothan, AL
    So... 4 quarts with Dexron VI, 3-4 quarts of Dexron IV ?
  11. #11 Re: And ... it begins.
    get what ever the newest DEXRON is but you will need prolly 7 bottles. When i did mine I bought 6 and had to go back and buy one more so thats why I say get 7 of them.
  12. #12 Re: And ... it begins.
    Pennsylvania
    ...why would you want dextron 4? Put in nothing but 6.
  13. #13 Re: And ... it begins.
    Jul 2010
    Dothan, AL
    re: Bluegtp91
    I read the thread @ http://www.grandprixforums.net/safel...car-17482.html
    Is there something I missed?
    you mentioned for me to read it.. . If I'm jumpin ahead, or screwin up. Please do let me know.... I don't wanna blow the engine! I looked online for "worst case" and found them selling for around 2700 minimum.. So.. yeah. Anything to prevent that would be great.
  14. #14 Re: And ... it begins.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Platinum plugs aren't recommended on a supercharged engine because they can create hot spots. It has nothing to do with the cost. On the other hand, as long as you aren't dropping pulley sizes on the blower, platinums shouldn't be a problem.
    I'm not sure why you would want to downgrade your spark plug wires, but whatever.
    GM has the aluminum LIM gaskets. Shouldn't be difficult to find.
    The headers are on ebay. Speed Daddy is the name of the seller.
    There is no such thing as Dexron IV. If you're talking about Dexron III, I don't see any real reason to use it anymore. You'll need 7-8 qt of Dexron VI (GM spec is 7.4 for a pan drop).
    The K&N intake and Jet MAF are pretty well useless.
    2001 Buick Regal LS - Almost Stock
  15. #15 Re: And ... it begins.
    It isn't really the point of lasting longer...it is hte point of copper plugs work very well in these cars...If you don't go colder then they will last about 20-30K...such as AL606's or a tad colder 605's. If you plan on modding and barely dropping pulley sizes then 605's will work great and last a long time for copper core plugs. I'm not saying that you can't buy them but since the cost of copper plugs are so cheap...but platinum plugs have just been proven to be beatin out by coppers everytime.
    As for the JET MAF...it also...has only been really truly proven to show a very maginal gain on LS4 cars...not the 3800...it is a waste of money...and the money you waste on a K&N Intake...I eve tel you in there...make your own for less than a 1/3 of the cost of that junk.
  16. #16 Re: And ... it begins.
    Jul 2010
    Dothan, AL
    Someone mentioned simply sticking the K&N Cone filter on the end of the MAFS....
    I understood the goal was to get the air intake as far away from the core of the engine (to get away from the hotter ambient temp towards the block)
    Someone else mentioned that the JET was unnecessary... soo thus lays the dilemma. I read here someone saying that w/ the GTP 3800 supercharger, air temp didn't matter.
    I'll respond more when I get some time to breathe... no pun intended.
  17. #17 Re: And ... it begins.
    QCA, IA
    I'm going to go against the grain here and say if you want spark plugs that will last longer and work well with boost, iridiums aren't a bad choice. NGK actually recommends them, and they're used successfully in numerous other car communities. The 3800 community is so set in it's ways that they've just brushed off iridium plugs.
  18. #18 Re: And ... it begins.
    Grand Rapids, MI
    Quote Originally Posted by Scimmia View Post
    Yes, iridiums would be a fine choice. The Autolite tech manager recommended these (refer to the quote in "Safely Modding your 3800 Engine").
  19. #19 Re: And ... it begins.
    New York
    Just get autolites lol. Either way your spark plugs will work lol. You should direct your attention to different things. It sounds like your pumped for your car which is a good thing. I started modding my car about 2 months ago and cant stop. But one thing i do reccomend is that you go to Pep Boys and buy everything you need to make your own CAI. Otherwise keep following up with safely modding 3800 engine forum and ask questions along the way. Also if you do plan on going with speed daddy headers be sure to buy a thicker flex pipe and some band clamps for them. As far as a tuned PCM goes i really reccomend that you talk to a guy on here named Reptile he does better tunes than 3800performance for cheaper. Last, always keep your head up. After dropping around 850 on my headers and intake i felt like i wasted money because i didnt feel any big gains. Once i put in the tuned PCM and 3.4" MPS i was a happy mofo. The tuned PCM gave my car a new personality and the 3.4"MPS changed the power. The large gains will come after the first couple mods. Stay on track
  20. #20 Re: And ... it begins.
    Jul 2010
    Dothan, AL
    wow.. Thank you all for the responses. I've not had the time I need to read everything just yet.
    But thus I gathered.. no need to buy nicer plug wires. Stick with the inexpensive copper plugs, no need for a MAFS changeout, and the air intake is questionable at this point...
    Aaaand, changing the headers and cat serves no purpose.
    I'm still changing the cat.. because the factory one is shot.. however, if I don't have to spend money on a new set of headers. I won't.
    I'm kinda lost here.. LoL
    Unless it might degrade performance, I'd still like to change the wires. (for the color LoL)
    Someone posted earlier that plat plugs get hotter and might crack pistons. That's baaaaad..
    Sooooo .. .stick w/ high quality copper plugs and go w/ recommended factory gap settings?
    All your advice is appreciated, and more is invited.
    Criticize if you like, I've got thick skin.
    before I give the mechanic the "go ahead' and order parts I'd like to know what I'm doing.. I plan on doing the labor with him..
    He has the tools and knowledge. I assume.
  1. and...the build begins *UPDATE*IDLE VIDEO!!!
    By glanzergtx in forum General Tech Discussion
    Last Post: 06-07-2010, 03:19 AM
  2. So the story begins with engine to tranny
    Last Post: 05-06-2009, 11:08 AM
