Thread: Fog Light replacement
Results 1 to 6 of 6
  1. #1 Fog Light replacement
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    What's the best way to change a fog light? From the back of the light, or front? What do I need to unscrew to change the bulb? I've climbed underneath to take a look, but it was a bit difficult to tell exactly what needed to be disconnected.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Fog Light replacement
    Michigan
    The best way is to unscrew the connector from the the back of the fixture. Once you do that the bulb will be in the connector. When you put the new bulb in the connector try not to touch the bulb with your fingers by using a clean soft cloth. When putting the connector with bulb back into the fixture, be careful not touch the bulb on the edges of the opening as not to scratch it.
  3. #3 Re: Fog Light replacement
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Yup unscrew the bulb a 1/4 turn to the left from the back of the fog light
    The connector and bulb will come out, pull the bulb out and put in a new one without touching the bulb as said above
    Align the bulb and screw it a 1/4 turn to the right until it locks in... DONE
  4. #4 Re: Fog Light replacement
    GTX Level Member bronzemist02's Avatar
    Canada
    ^ I agree. I put some cardboard down and crawled under and did mine. Had the car on a hoist when the hids were put in though. lol.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  5. #5 Re: Fog Light replacement
    Feb 2008
    Cumming GA
    Thanks for the advice. Hopefully should have some snow melt to give me a chance to climb under the car without freezing on ice.
  6. #6 Re: Fog Light replacement
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    I just took my jack and lifted it up about 10". Im a noodle and couldnt squeez under my GS
  1. GXP Fog Light replacement
    By zarif in forum General Tech Discussion
    Last Post: 03-12-2011, 04:23 PM
  2. light in a/c controller needs replacement
    By grandprix97gp in forum General Tech Discussion
    Last Post: 11-09-2010, 09:06 PM
  3. Fog light replacement?
    By TwistedMexi in forum Visual/Body Modifications
    Last Post: 10-06-2010, 04:39 PM
  4. Does anyone know where i can find a 3rd brake light replacement?
    By Stiffler419 in forum General Tech Discussion
    Last Post: 09-02-2010, 02:27 PM
  5. Need Instructions on signal light switch replacement
    By ragtops in forum General Tech Discussion
    Last Post: 03-22-2009, 05:44 PM
