Thread: front end noise, what else...?
Results 1 to 7 of 7
  1. #1 front end noise, what else...?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    so ive had this noise on my front passenger side.... its a loud metal on metal banging noise; picture 2 large wrenches in a tool box, and the banging noise they would make every time you hit a bump. thats the noise im hearing.
    so far ive replaced the front control arm bushing, and the sway bar link. the hub/bearing is new, and the shock/strut and cv shaft is about a year old. ive disconnected both the outer tie rod link and the ball joint and both feel pretty solid to my feel.
    what should i try next?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: front end noise, what else...?
    Charles City, IA
    Did you replace sway bar bushings? Also did you get a new strut mount when you did the strut.
    SMGPFC Two Nipple General
  3. #3 Re: front end noise, what else...?
    Nov 2008
    Fremont Nebraska
    i havent replaced either of the sway bar bushings, only the 1 sway bar link on the passenger side. the struts were replaced with quick struts, so everything strut related is newer.
    would you happen to know the diameter of the stock sway bar?
  4. #4 Re: front end noise, what else...?
    Nov 2008
    Fremont Nebraska
    alright, both sway bar bushings and both sway bar end links are now new. problem hasnt changed.
    what else could it be?
  5. #5 Re: front end noise, what else...?
    SE Level Member RideMr2's Avatar
    Memphis
    I am wondering if it could be the intermediate shaft, but I don't know if your model grand prix has issues with it.
  6. #6 Re: front end noise, what else...?
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    check 2 make sure that your brace that runs from the strut tower 2 your rad support is tight that will cause a popping sound. Also if your dog bones are bad that will also cause popping sound on front end from motor moving 2 much. Hope this helps!!!
  7. #7 Re: front end noise, what else...?
    Nov 2008
    Fremont Nebraska
    delete..
  1. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  2. Front end noise
    By squirrel in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 10:50 PM
  3. Right-Front Grinding Noise
    By cowmilker08 in forum General Tech Discussion
    Last Post: 06-07-2010, 01:36 PM
  4. front end noise, hub?
    By hourang in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2010, 11:17 AM
  5. Roar noise from front end
    By markh in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:37 AM
