Thread: stainless steel u bend reducer purchase on hold
Results 1 to 20 of 23
  1. #1 stainless steel u bend reducer purchase on hold
    GTP Level Member tazyboy28's Avatar
    home town
    hey guys i was going to purchase this u bend reducer for its properties: ZZ Performance
    from wat i read it reduces a 3in opening to a 2.5in and my down pipe is 3 but my catback is 2.5. Before i purchase this i wanted to know if i was purchasing the right thing. and if i am purchasing the right item is $69 to much or can i get it cheaper. because ive been looking and dnt think anyone else sells this item with an already welded flange that i need.
    thanks for any input.
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  2. #2 Re: stainless steel u bend reducer purchase on hold
    im glad youre so willing to pay that much money for something you dont need.
    you can also piece together a flange and a reducer for like $7.
  3. #3 Re: stainless steel u bend reducer purchase on hold
    Bastard Reptile's Avatar
    Kansas City, MO
    Wait....don't the '04's not have the Ubend?
    And furthermore if you have ZZP Headers, why?
  4. #4 Re: stainless steel u bend reducer purchase on hold
    Pennsylvania
    I'm not sure what you think you're trying to fix. Put the money form the part, shipping, and paying someone to cut up and re-weld your exhaust into a tune.
  5. #5 Re: stainless steel u bend reducer purchase on hold
    home town
    omg thats what im saying, idk where to get these items....
    Quote Originally Posted by Reptile View Post
    and im not sure u read wat i wrote . . . I HAVE A 3 INCH DOWN PIPE, MY CAT BACK IS 2.5 . . .SO THEY DO NOT CONNECT PROPERLY.
  6. #6 Re: stainless steel u bend reducer purchase on hold
    home town
    Quote Originally Posted by SlowNA06 View Post
    WOW i have an exhaust leak because both ends dnt match. so i should ride around with a loud exhaust and use that money to tune my pcm.
    i dont knw about the ideas im getting . . .
  7. #7 Re: stainless steel u bend reducer purchase on hold
    Charles City, IA
    Step one. Go to any exhaust shop
    step two tell them what you need
    step three put it on.
    SMGPFC Two Nipple General
  8. #8 Re: stainless steel u bend reducer purchase on hold
    home town
    i did . . . two different miniekes, they dnt have 3 inch pipping, they said i need to buy it and theyll put it on. thats why im asking if any other websites have it so i can just makeit happen.
  9. #9 Re: stainless steel u bend reducer purchase on hold
    Kansas City, MO
    Quote Originally Posted by tazyboy28 View Post
    OK,
    #1, I'm only trying to help, so you can cut the A-hole attitude. I looked at your "specs" list, you say that you have ZZP headers, I know they come with a 3" downpipe, they also bolt up to the stock cat back if you select that option. Forgive me for actually looking at your signature to figure out what you're asking.
    #2, the link you post goes to a U-Bend delete pipe, which is why I thought you were still confused on what you were actually looking for.
    So with that, have a great day figuring this out without my help.
  10. #10 Re: stainless steel u bend reducer purchase on hold
    home town
    OK,
    wat a hole attitude???? im not sure but u must be mistaken, i told u that u might have not read wat i wrote the first time, sometimes ppl over look things. and then i go on to quote wat i wrote in the first post????
    where in the post does there indicate that i have some type of attitude wen i adressed u with no type of disrespect??? smh
  11. #11 Re: stainless steel u bend reducer purchase on hold
    SE Level Member OnMy2ndGP's Avatar
    Feb 2010
    Maryland (DMV)
    Tazyboy28, told ya b4...u r better off going to a custom exhaust shop and have then fix it up.
    BTW....ROTFLMAO!!!
  12. #12 Re: stainless steel u bend reducer purchase on hold
    Aug 2008
    KCMO
    that sucks that they are charging that much for that thing. when i bought my 3in to 2.5in reducer it was only 9 dollars and the shipping was 8 dollars
  13. #13 Re: stainless steel u bend reducer purchase on hold
    home town
    Quote Originally Posted by carl06GT View Post
    thats what i thought it was . . . and it was from ZZP right? wen was this?
  14. #14 Re: stainless steel u bend reducer purchase on hold
    You have ZZP headers and a SLP Powerflo...I don't see the issue...there is no problem going from a 3" pipe to a 2.5" catback...reducers are stupid and so are you for going to Mieneke thinking your going to get quailty work. If you have an exhaust leak with ZZP headers then you didn't install them right. Reptile and I put his on in under 2 hours with no leaks. Your car didn't come with a U-Bend from the factory...so that thing won't help you anyways.
  15. #15 Re: stainless steel u bend reducer purchase on hold
    home town
    no no no im saying the 2.5 inch flange does not bolt up to the 3 inch flange. a 2.5 and a 3 inch dont bolt up together thats why i need the reducer so the 2.5 end can be welded to the catback and the 3 inch side can be bolted to the downpipe. and theres not exhast leak from the headers its in the middle from where the flanges are suppose to bolt together. . . that is the only area where it isnt connected properly. argh lol
    but anyway i think i found some parts after saying forget 3800 sites and lets take a look in to other sites.
    Flowmaster Exhaust Reducer - Universal Product
    Universal
    FLOWMASTER VENTURI REDUCER CONE, SOLD AS PAIR -- 8 Long, 3 Inlet Diameter, 2.5" Outlet Diameter, A Slip-On Exhaust Pipe Reducer That Provides Smooth Transition Between Pipes Of Different Diameter Sizes, With Manufacturer's Limited 3-Year Warranty
    Type: Universal product: Parts Bin - Auto Parts and Accessories Catalog - flowmaster exhaust reducer - universal product - Flowmaster Exhaust Reducer
    DIF 10002 3" 2-Bolt Universal Exhaust Flange Slip-Fit 3/8" Thickness:
  16. #16 Re: stainless steel u bend reducer purchase on hold
    Pennsylvania
    Maybe I'm asking a stupid question here: If you're spending all this money on exhaust, why not go full 3" the whole way?
  17. #17 Re: stainless steel u bend reducer purchase on hold
    home town
    naw its not stupid. thats wat i was going to do but i already purchased the catback before the headers because my original stock one was bent by a curb wen i was backing up. so i just bought a replacement . . .then i had enough money to get headers. then during installment i realized it didnt connect iwas going to by a nother catback but thats just a waste of more money.
  18. #18 Re: stainless steel u bend reducer purchase on hold
    Charles City, IA
  19. #19 Re: stainless steel u bend reducer purchase on hold
    home town
    lol watever. i already googled it and posted it in the post above urs.
  20. #20 Re: stainless steel u bend reducer purchase on hold
    Then something is wrong with your sh1t. ZZP headers bolt-up to any catback that is mass produced or the stock one. Sorry for your mishap
  1. Are ssac headers actually stainless steel?
    By OH4CompG in forum General Tech Discussion
    Last Post: 12-03-2009, 01:12 AM
  2. Stainless steel brake hoses
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2008, 06:18 PM
