Thread: Noisy Idle/Coolant leak
Results 1 to 6 of 6
  1. #1 Noisy Idle/Coolant leak
    SE Level Member Flava601's Avatar
    Hattiesburg
    Hey guys. Anybody know what could cause my 2000 grand prix gt to suddenly start sounding really loud upon starting and idling? Started about a week ago. Sounds like an exhaust leak would sound or bad catalytic converter but that isnt the case. I pulled her up on ramps and crawled underneath with flashlight and inspected. Sound is mainly towards front of car. I also noticed a little coolant around the area where air intake body is. Anybody got any ideas?
  2. #2 Re: Noisy Idle/Coolant leak
    Apr 2009
    California
    I have a similar problem with my '98 GTP. The sound is loudest for the first minute after start up and then it almost goes any. It is loudest near the #5 cylinder exhaust manifold.
    Have you found a solution yet?
  3. #3 Re: Noisy Idle/Coolant leak
    St. Louis
    Is there any signs of coolant in the oil? Should look like a milkshake. Check the underside of the oil fill cap as well.
    Sounds like your leaking coolant around the TB due to the UIM being warped/cracked. If you haven't replaced the LIM gaskets it would be a good time to do that as well to avoid future issues. ineedparts.com sells a good kit for the UIM that includes everthing you would need to do the work. Been running mine for over a year and no issues.
  4. #4 Re: Noisy Idle/Coolant leak
    Hattiesburg
    Hey guys. Quick update. Mine was doing that exact same thing, (loud at startup then sound disappears). I removed the heat shield for the Exhaust Manifold and found that the manifold itself was cracked. Got a replacement from Autozone for $70 and problem solved. Procedure was pretty simple. Just remove motor mounts and allow engine to roll backwards a lil and spray bolts with some PB Blaster for easy removal. The rest is pretty self explanatory. As far as coolant leak I still have'nt found a significant reason. The oil isn't milky and the leak seems to have disappeared. My coolant reservoir did feel a lil greasy near the top when I rubbed my finger in it. Engine not overheating or anything. I've been keeping a close eye on it. Is the UIM job pretty hard?
  5. #5 Re: Noisy Idle/Coolant leak
    Apr 2009
    California
    I pulled my heat shield off and I too had the same problem, the exhaust manifold had cracked all the way around between the #3 and #5 exhaust outlets. It took me about 2 hours to replace working in a parking lot far from my tool storage. I'm not sure why Flava601 needed to "remove motor mounts and allow engine to roll backwards a lil". Everything was pretty accessable except getting the torque wrench straight to torque the flange bolts.
  6. #6 Re: Noisy Idle/Coolant leak
    St. Louis
    I think he meant remove the dogbone mounts from the rad support and then rock the motor towards the front of the car, thus allowing more room in the back
  1. Coolant Leak..help
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2009, 10:56 PM
  2. coolant leak
    By cheesewhiz in forum General Tech Discussion
    Last Post: 10-22-2009, 01:11 PM
  3. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
  4. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  5. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
