Thread: ignition problem
Results 1 to 20 of 33
  1. #1 ignition problem
    GT Level Member mvp2765's Avatar
    Chicago
    So i've been searching for a week how to fix this problem. My windows are down and i need them up along with not being able to start my car.
    The problem is that i cannot turn the key either direction in the ignition. The ignition is stuck in the off position.
    I removed the white solenoid which locks the key in and it did not make a difference. I tried jiggling the key for hours, i tried turning the wheel and shifting the through the gears of the transmission, i do not know what to do. I am guessing that it is the ignition lock cylinder.
    I have most the dash and trim around the steering wheels off. Do i need to take off the steering wheel to replace that part?
    - Any tips/info/solutions would be much appreciated..Thankyou
    00 Black GTP Coupe - SOLD
    04 Black 350Z touring -currently modding
  2. #2 Re: ignition problem
    Chicago
    also because i cant turn the ignition forward, i cant remove the ignition lock cylinder to replace..
  3. #3 Re: ignition problem
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    hammer does wonders lol jkjk
    but im sure someone else will chime in
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  4. #4 Re: ignition problem
    Grand Rapids, MI
    ^^ LOL! i was gonna say to just force it. if youre gonna put in a new one...who cares if the old one breaks [by force]
  5. #5 Re: ignition problem
    Waterloo, Iowa
    thats my theory...crowbar should make it pop off like nothin!
  6. #6 Re: ignition problem
    Grand Rapids, MI
    Quote Originally Posted by putskijr View Post
    i like your way of thinking
  7. #7 Re: ignition problem
    Chicago
    haha, im actually resorting to that now..i just didn't know if the housing or what ever its called would break along with the ignition lock cylinder
  8. #8 Re: ignition problem
    Chicago
    yay, good advice, a hammer worked..lol...i smashed it in till it popped and i was able to turn the ignition forward to remove it..
  9. #9 Re: ignition problem
    Grand Rapids, MI
    Quote Originally Posted by mvp2765 View Post
    success!! now for the new
  10. #10 Re: ignition problem
    Waterloo, Iowa
    haha that'd be $5 for advice jkjk glad u got it fixed!
  11. #11 Re: ignition problem
    Sep 2013
    ST.LOUIS
    Im having the same problems on a 97.key wont turn forward to start,sometimes backwards.anyone have a real answer for this problem to get the cylinder out?is this guy saying that he beat onnthe lock with a hammer hitting a flat head in the cylinder?
  12. #12 Re: ignition problem
    if the key is hard to push in the lock i'd try some graphite lock spray. if its just the tumbler being dry it should help.
    sadly the only way to get the tumbler out is if the key is turned to run, theres a hole you push a pick into on the top of the column and then you pull the tumbler out with the key in it still.
  13. #13 Re: ignition problem
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    It's usually the white solenoid holding the key in, can be released by removing it/replacing it or shoving something up the hole under the column to release it.
    OR could be this: https://www.youtube.com/watch?v=2rHb...uDCZN23FRqKVf4=
  14. #14 Re: ignition problem
    Sep 2013
    ST.LOUIS
    Thanks for the help.i tried spraying wd40 in the lock no luck,ill try the graphite spray next.the key is not stuck it wont turn to the on position,only turns backwards.and if i ever get the new lock in will it need to be programmed by a dealer or just install and good to go?thanks everyone.
  15. #15 Re: ignition problem
    this how to gets you to the tumbler and the lock solenoids. http://www.sparkys-answers.com/2009/...-changing.html
    it says 2002 gp, but its all the same, my 98 regal was the same too. used this myself to change my harness.
  16. #16 Re: ignition problem
    Sep 2013
    ST.LOUIS
    Thanks but my key wont go into the on position to take the lock out
  17. #17 Re: ignition problem
    it may once the lock solenoid is removed. or unplugged.
    i stripped a column i got for parts. it was out of the car and had no power to it of course, it all came apart still.
  18. #18 Re: ignition problem
    Sep 2013
    ST.LOUIS
    Ill try again tomorrow.is the lock solenoid the white thing that has a piece of metal that comes in and out?the weird thing is when i took the plastic off the column that white thing was plugged in but just hanging there,i put it where itngoes and no change.that metal pin like thing does move freely still
  19. #19 Re: ignition problem
    SE Level Member jimzssei's Avatar
    Sep 2014
    Is there a cable that runs to the shifter on the GPs? My Bonnie was stuck, and ended up removing the cable from the ignition switch and success. Just a thought.
  20. #20 Re: ignition problem
    Sep 2013
    ST.LOUIS
    Yah i have bonneville ssei.im so pissed lmfao!my bonneville shifter lock solenoid broke the same day 3 days ago.the same day my grand prix stopped turning over.talk about ****ing mad.the shift lock solenoid i think is on the column.im gonna go out now and try to un plug the solenoid.
  1. Ignition problem
    By kamamm in forum General Tech Discussion
    Last Post: 01-16-2010, 10:38 AM
  2. 94 3.1 has ignition problem
    By 94prixer in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-13-2009, 01:53 PM
  3. Ignition Problem-Please Help
    By elbowcoffeecup in forum General Tech Discussion
    Last Post: 07-29-2009, 07:39 AM
  4. Help IGNITION KEY PROBLEM
    By cool50 in forum General Tech Discussion
    Last Post: 02-28-2009, 11:57 PM
  5. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
