Thread: growling screaming once i hit 45
Results 1 to 3 of 3
rmil03 growling screaming once i hit... 07-31-2010, 08:08 PM
noreasonwhyy Re: growling screaming once i... 07-31-2010, 09:15 PM
AmericanRiceEater Re: growling screaming once i... 08-02-2010, 02:15 PM
  1. #1 growling screaming once i hit 45
    SE Level Member rmil03's Avatar
    Jun 2010
    jersey
    my engine growls really loud once im about at 50, if i turn slighty right it goes away, but other then that it seems to be screaming, i changed all my fuilds and i just cant figure it out...any input?
    '01 gpgt, tinted tails, k&n custom intake, lime green engine bay, straight pipe exhaust, gold/black interior. dirrrrrtydir
  2. #2 Re: growling screaming once i hit 45
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    sure it's your engine making the noise?
    it's probably the wheel bearing/hub assembly
  3. #3 Re: growling screaming once i hit 45
    GT Level Member AmericanRiceEater's Avatar
    New York
    I had a problem like this. It took my wheel to pop and set off 5 car alarms in Wal-Mart parking lot to find out what the problem was. For me i had a broken strut that was rubbing against the side of my tire every time that i turned the wheel to the right. You should be careful man. I'm lucky my wheel didn't blow when i was on the highway.
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  1. Power Steering is SCREAMING. HELP A GIRL OUT!
    By Princess in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:16 PM
  2. growling noise
    By tjs84c10 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-13-2008, 02:06 AM
