Thread: 2001 gt 3800 v6 stock motor
Results 1 to 5 of 5
  1. #1 2001 gt 3800 v6 stock motor
    Donating Users flower50's Avatar
    Jun 2010
    OHIO
    have dual air conditioning was very cold ran gr8 for about a month ,pass side cold ,drivers side warm,now both are blowing warm air ,anyone have ideas for a cheap fix ,this heat wave is killing me 4sure
  2. #2 Re: 2001 gt 3800 v6 stock motor
    GT Level Member sic6's Avatar
    san marcos, tx
    Check to make sure your a/c clutch is engaged on the compressor.If it is check the low side a/c line it will be the larger of the two metal lines, it should be cold to the touch.If all that checks out ok then more than likely your blend door actuator is not working and is stuck on the default mode for heat.
  3. #3 Re: 2001 gt 3800 v6 stock motor
    Jun 2010
    OHIO
    thank you sooo much what a nice person you are will give it a try
  4. #4 Re: 2001 gt 3800 v6 stock motor
    hoooray for this being in the TRANSMISSION SECTION...so smart...
    moving..
  5. #5 Re: 2001 gt 3800 v6 stock motor
    Jun 2010
    OHIO
    so sorry trying to learn to navigate site,give me a break
  1. 2001 grand prix 3800 heat issues. HELP PLEASE
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 06:47 PM
  2. GTP 3800 Motor swap into 2001 Grand Prix SE 3.1 body
    By HomeBoyShopnClub in forum General Tech Discussion
    Last Post: 08-19-2009, 07:45 PM
