Thread: Plog slowed me down.
Results 1 to 5 of 5
  1. #1 Plog slowed me down.
    SE Level Member 4boostin's Avatar
    Feb 2010
    Utah
    Here's a question for you all...After I put a Plog on I have not been able to run as fast. My ET is down about 2 tenths and the MPH is also down 2mph's after installing the Plog with the 3.6 pulley. I had all the mods in my signature except the PLOG, when I ran 14.65 @ 96.9. So, I tried a 3.4 pulley with enough 100 octane to eliminate KR. According to the Butt Dyno, it felt faster, but it was not....still down 2 tenths and 2mph....and the conditions and temps were very much the same.....and I'm scanning with an AeroForce.
    I'm guessing that because I'm running a stock PCM, that I need a tune to add a little more fuel to match and take advantage of the increased air flow from the Plog?
    What do you all think?
    98GS - 3" DP & Cat back, 9" K&N CIA in FW, Plog, 3.5", 180* Canned tune. 14.65 at 96.9mph, w/2.37 60ft. on G-Timer @ 4500 elev. @ 51*.
    87 Limited Turbo Regal- 12.04 @ 115 -Purchased New. Sold after 23 years and 115,000 miles
  2. #2 Re: Plog slowed me down.
    Donating Users Ibwrong's Avatar
    Oklahoma City
    tune... and as cheap as headers are now a days might be worth the 220 shipped.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: Plog slowed me down.
    Outer Space
    when i was plogged... I skewed the front injectors 3%. Fastest I ran was 14.05 @96mph on a stock pulley, rockers, dp, plog, zzp pcm.
    Getting a PCM would definitely help you.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: Plog slowed me down.
    Portland Oregon
    That 60' time sucks. That's where you're losing your ET. If you can knock a few tenths off your 60' you can drop a lot off of your ET
  5. #5 Re: Plog slowed me down.
    Donating Users blowfishRus6's Avatar
    g.a.
    i did zero tuning when i put headers on and picked up a good bit on my et and mph.
    my first guess was gonna be track conditions/bad air. you sure the D/A was the same?? idk.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. PLOG
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2009, 12:44 PM
  2. Plog
    By 0LmtdGP3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 11:29 AM
