Thread: AC clutch rattling and vibrating when engaged!
Results 1 to 6 of 6
  1. #1 AC clutch rattling and vibrating when engaged!
    Thunder bay,Ontario.Canada
    The ac clutch on my 99 started rattling yesterday. I know its the clutch, my question is: can the clutch be replaced or am I going to have to replace the compressor, if so where can a replacement clutch be bought & what special tool are required if any? Does anyone have any video links on the procedure?
    Thanks to all that respond, Mark
  2. #2 Re: AC clutch rattling and vibrating when engaged!
    Charles City, IA
    Generally a bad clutch will only rattle until engauged I am thinking you need the whole beating clutch assembly or possibly a compressor you will newer a GM clutch and bearing removal tool
    SMGPFC Two Nipple General
  3. #3 Re: AC clutch rattling and vibrating when engaged!
    HUDSON
    Probably the bearing in the clutch pulley is bad. Generally they are simple to change out and come with new pulley,bearing,clutch, and often a special puller is needed, somtimes a puller is not needed, depends on design and compressor type.
    When the clutch pulley bearings are bad, it will make noise with a/c on or off because the pulley is always spining when the engine is running.
  4. #4 Re: AC clutch rattling and vibrating when engaged!
    Panama City Beach, FL
    Do yourself a favor and buy a compressor with clutch.
  5. #5 Re: AC clutch rattling and vibrating when engaged!
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    i just put a bypass pulley on mine... 40 dollars is better then 253 dollars.
  6. #6 Re: AC clutch rattling and vibrating when engaged!
    Quote Originally Posted by bandits grand prix View Post
    And ball soup is priceless.
  1. who's engaged? im engaged.
    By Bio248 in forum Off Topic Discussion
    Last Post: 05-19-2011, 11:05 AM
  2. Vibrating issues
    By Piggy in forum General Tech Discussion
    Last Post: 01-31-2010, 12:44 AM
  3. Im engaged!!!
    By BoostJunki3 in forum Off Topic Discussion
    Last Post: 09-13-2009, 06:30 PM
  4. Pulling to the Ditch and Vibrating
    By Hawkins97 in forum General Tech Discussion
    Last Post: 08-05-2009, 02:16 AM
  5. Car Vibrating badly
    By bcrosby51 in forum General Tech Discussion
    Last Post: 07-23-2008, 07:52 AM
