Thread: gen v pcv fix....HELP PLEASE
Results 1 to 10 of 10
  1. #1 gen v pcv fix....HELP PLEASE
    Joliet, IL
    ok this is the issue im having....the pcv nipple on the back of the genv is creating a suction.....the nipple on the l67 tb is also creating a suction....
    ive seen write ups that say connect the one on the genv to the tb to fix it and block off the evap connection on the blower, mine is jb'd shut.
    i had no idea pcv wasnt functional until i heard a loud whistling when driving and when i tried to pop off the oil cap it had a suction (at this time both nipples were vac capped.) when i remove the genv cap and leave the tb capped i get no oilcap suction or loud whistling/squealing. here are pics below about what im talking about.....could the pcv just be bad? weird thing is i drove with both capped for awhile with no squealing or whistling but i just fixed a leaky front valve cover today and the gasket was bad so maybe it was escaping there and preventing whistle....pcv has free play when shook and the plastic shaftgoes in then pcv valve then spring and cap.....cant figure it out.
    l67 tb connection
    genv connection on back
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: gen v pcv fix....HELP PLEASE
    Joliet, IL
    bump for some answers. should the genv fitting be having a vacuum or blowing out because it has a vacuum.
    00 Silvermist GTP
  3. #3 Re: gen v pcv fix....HELP PLEASE
    Portland Oregon
    AFAIK the nipple on the back of the gen v is a vent. Mine is plumbed into my intake just before the throttle body
  4. #4 Re: gen v pcv fix....HELP PLEASE
    Joliet, IL
    then why is mine creating a suction?
    00 Silvermist GTP
  5. #5 Re: gen v pcv fix....HELP PLEASE
    Your PCV valve isn't sealing then...
  6. #6 Re: gen v pcv fix....HELP PLEASE
    Joliet, IL
    so how do i fix that?
    00 Silvermist GTP
  7. #7 Re: gen v pcv fix....HELP PLEASE
    to be quite honest, i dont know how the pcv system works in these cars with blowers.
    the nipple on the TB should have vacuum, how else would it operate the other devices off of it?
  8. #8 Re: gen v pcv fix....HELP PLEASE
    Joliet, IL
    the nipple on the gen v also has vac when its supposed to be a vent.....theoretically i should be able to connect the genv and tb nipple and be fine but it screams when i do this.
    00 Silvermist GTP
  9. #9 Re: gen v pcv fix....HELP PLEASE
    Portland Oregon
    Sorry, I'll correct myself. By vent I mean an air inlet vent. It is there to suck air in. The reason it's plumbed into the air duct before the throttle body is to draw in clean filtered air.
  10. #10 Re: gen v pcv fix....HELP PLEASE
    Joliet, IL
    ok guys figured it out i drilled and tapped the brass fitting on the bottom of the tb and jb welded a fitting in the hole and ran a hose from the gen v nipple to the new fitting problem solved!
    00 Silvermist GTP
