Thread: Polly dogbone bushings?
Results 1 to 20 of 22
  1. #1 Polly dogbone bushings?
    Jun 2010
    Usa
    Is this just straight forward or is it more involved?
    what all do i need to do?
    do i need to suport the engine?
    any help wanted!
    Thanks!
  2. #2 Re: Polly dogbone bushings?
    easy as pie. unbolt. figure out how to get the stockers out (most difficult part) then pop the poly's in, reasseble and you're done.
  3. #3 Re: Polly dogbone bushings?
    its pretty straight forwards. you're going to have to cut out the stock bushings unless youre a magician. its best to press the poly bushings in with a vice (easiest).
    you also dont have to support the motor.
  4. #4 Re: Polly dogbone bushings?
    Jun 2010
    Usa
    thanks guys!
    do you have them on your car?
    can you notice the diffrence?
    are they worth it?
  5. #5 Re: Polly dogbone bushings?
    yes. yes. yes.
  6. #6 Re: Polly dogbone bushings?
    Jun 2010
    Usa
    yes. yes. yes.
    Just what i wanted to see!
    thanks!
  7. #7 Re: Polly dogbone bushings?
    Donating Users Warbeaver's Avatar
    St. Louis
    mine came out easy. just take some wire snippers, and cut the rubber lip of the bushing on one end. do it all the way around. Then just take a screwdriver and push the bushing out the other end. those lips are the only thing keeping them in the dogbone.
    then just slide the new ones in. it helps to use some grease when putting in the poly bushings. i would do it just in case they try to get squeaky
  8. #8 Re: Polly dogbone bushings?
    Akron Ohio
    Where can I get theas at, and how much are they? I have a rattle somewhere and I think its from my Moter mounts It only happens when its in drive. any one know what it is?
  9. #9 Re: Polly dogbone bushings?
    Brewcity, WI
    Quote Originally Posted by joshsgtp View Post
    W Body Store
    ZZ Performance
    Not sure what the difference is? I've got the offset ones from ZZP and have had'em for ~4 years, with no problems at all. You should get the offset ones if your lowered.
    edit... nevermind, on ZZP website
    Offset mounts are discontinued, if you still want to rock the engine forward, then the shorter dogbones are what you are looking for
    As far as the noise... it could be that, or alot of other things.
    Self-denied SMGPFC member #1
    SEARCH works!
  10. #10 Re: Polly dogbone bushings?
    get intense poly mounts (they are the only ones who offer the round bushings anyway). they are a little softer compound that the ones that zzp uses.
    http://intense-racing.com/Merchant2/...tegory_Code=BS
    i had both on my car and loved the crap out of them.
  11. #11 Re: Polly dogbone bushings?
    St. Louis
    x2. intense were the only ones i used. much softer and quieter than the zzp mounts i had.
  12. #12 Re: Polly dogbone bushings?
    Nov 2008
    Chicago
    I've been known to burn stubborn rubber bushings with a MAPP torch as a last resort.
    97 GTP Sedan: 3" from the downpipe to the mufflers, no cat, ADR 17's, AGX/Eibach, HAI w/k&n, 6k HID's
  13. #13 Re: Polly dogbone bushings?
    Jun 2010
    Usa
    so what's the diffrence between square and the round ones other than shape?
  14. #14 Re: Polly dogbone bushings?
    one fits one side, one fits the other.
  15. #15 Re: Polly dogbone bushings?
    Odessa, MO
    I read on the Stacey David's Gearz website that freezing poly bushings will make them shrink up a bit and make them easier to press in. I'd be curious to see if that's the case with the square ones. I use a vice to press them in but it would be interesting to see if this made it any easier.
  16. #16 Re: Polly dogbone bushings?
    Charles City, IA
    Just lube them up a lot with wd40 or jb80 sinces its twice as good. Then wack them in with a rubber mallet.
    SMGPFC Two Nipple General
  17. #17 Re: Polly dogbone bushings?
    GT Level Member Mitchstrp's Avatar
    Missouri
    ^^^^ this is what i did. took no time at all
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  18. #18 Re: Polly dogbone bushings?
    Mine were used so they popped right in the first time.
  19. #19 Re: Polly dogbone bushings?
    Charles City, IA
    Just like your ex.
  20. #20 Re: Polly dogbone bushings?
    SHAZam!
  1. Need help dogbone information
    By flyhy in forum Introductions/Noob Questions
    Last Post: 04-21-2010, 08:44 PM
  2. Anybody know the torque of install dogbone?
    By ya61x in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2010, 07:48 AM
