Thread: Wheel Popping in and out
Results 1 to 11 of 11
  1. #1 Wheel Popping in and out
    SE Level Member 2000GrandPrixGTP's Avatar
    Jun 2010
    Michigan
    I have a 2000 Pontiac Grand Prix GTP and have a problem with my front wheels. When I push on the wheel with my foot it move in at least 1/4 of an inch. I replaced the wheel hubs and I'm going to do the cv halfshafts next. But before I buy them i want to make sure that the halfshafts are at fault.
    Would a bad cv halfshaft cause the wheel to move in and out or do I have a defective wheel hub? There is a grinding type noise while driving and vibration at higher speeds. No popping while turning. Brakes were just done so that's not the grinding.
    Thanks for any input
  2. #2 Re: Wheel Popping in and out
    Like the car moves back and forth a 1/4 in. If the car is in park and the E-Brake is off that is all normal.
  3. #3 Re: Wheel Popping in and out
    Jun 2010
    Michigan
    No I mean when you push on the wheel from the side towards the engine. I know the car will go back and forth if you push it lol. The wheel moves in and out as in side to side
  4. #4 Re: Wheel Popping in and out
    Oh, then I guess I am clueless on this. Hopefully someone else on here can help you. lol
  5. #5 Re: Wheel Popping in and out
    Apr 2009
    stockton ca
    thats weird i dont think its the cv's though maybe ball joint
  6. #6 Re: Wheel Popping in and out
    Charles City, IA
    Have some one else push on the wheel and you look and see what is moving. It is probably an inner or outer tie rod.
    SMGPFC Two Nipple General
  7. #7 Re: Wheel Popping in and out
    Jun 2010
    Hampton, VA
    Could be tie rod ends but with a grinding noise while in motion I would check the hub for bad bearings since that would also cause "play" in the tire. just a thought.
  8. #8 Re: Wheel Popping in and out
    GT Level Member 99GPGTP's Avatar
    Rome GA
    check lower ball joint and tie rod ends.
  9. #9 Re: Wheel Popping in and out
    Delaware, OH
    CV shafts won't cause that. They don't hold anything in place.
    Check the following.
    1. Lower Ball Joint.
    2. tie rod ends
    3. bolts between the spindle and strut.
    4. point where strut mounts to the body.
    My guess is the bolts at the spindle and strut are loose.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  10. #10 Re: Wheel Popping in and out
    memphis
    Ball joints
  11. #11 Re: Wheel Popping in and out
    Charles City, IA
    Quote Originally Posted by Ice Blue La Crosse View Post
    Ball joints
    If the ball joint is not designed to move side to side how are you going to turn? please dont suggest parts that have nothing to do with the issue.
  1. Popping noise from the rear
    By tjhgtp86 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2010, 11:29 PM
  2. Popping In Reverse
    By Chmanzi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2010, 11:00 PM
  3. popping sound
    By flatblackgtp16 in forum General Tech Discussion
    Last Post: 07-30-2009, 12:15 AM
  4. another popping thread....while turning
    By cmashark in forum General Tech Discussion
    Last Post: 04-02-2009, 04:46 PM
  5. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
